This is my interpretation of the vacumn diagram for the VNT's.
Standing in front of the car looking at the engine the 1st solenoid in the group of 3 solenoids mounted to the passenger inner fender is the purge solenoid. The lower nipple is capped, the middle nipple goes to the port on the vapor canister and the top nipple goes to the vacuum connector.
The 2nd solenoid is VNT#3. The bottom nipple is capped, the middle nipple of the solenoid goes to the top nipple on the turbo actuator. The top nipple of the solenoid goes to the top port on the side of the turbo compressor housing.
The 3rd solenoid is VNT#2. The bottom nipple goes to the front nipple of the solenoid that is mounted on the shock tower which is VNT solenoid #1 (I'm calling the front nipple the one that is facing the engine). This line also has a tee with a line going to the bottom port on the turbo actuator. The middle nipple is capped. The top nipple goes to a line that is tee'd, with 1 line going from the tee to the rear of the solenoid mounted to the shock tower (rear nipple would be the one facing the fender) and the other line from the tee going to the vacuum connector.
The baro solenoid that is on the bracket with the map sensor has the bottom nipple capped, and the middle nipple going to the map sensor. The top nipple goes to a tee, with 1 line going from the tee to the fuel pressure regulator and the other line going from the tee to the vacuum source.
The lower port on the side of the turbo housing goes to a tee. 1 of the lines from the tee goes to the air cleaner and the other line goes through a check valve which then goes to a tee. 1 line from the tee goes to the speed control servo and the other line from the tee goes to a check valve and continues on to the port on the brake booster.
I would suggest you print out the vacuum diagram to follow along.
http://www.thedodgegarage.com/turbo/turbo90vnt.jpg
If anyone has a simplification or correction on this please post it. Thanks Mike
