04-22-2005, 03:41 PM
#19
I was wondering why your PCV hose "blew off" as it is only connected to vacuum sources, there should never be boosted pressure on it. If you are getting a pressurized crankcase so that you get vapor out the dipstick tube and the oil filler cap, it is time to do a compression check on the cylinders.
Sounds like serious blow by, usually caused by cracked/broken piston ring lands. But if it happens only under boost, and not at idle, then maybe you have a vacuum line that is connected wrong and is pressurizing the PCV system and the crankcase.
Do a compression check to be sure which area to look at.
Barry
