03-27-2005, 03:41 AM
How does a VNT perform when the 'V' quits working?
My Ride: 86,87, and 90 Turbos
I am wondering if a VNT car will exhibit turbo lag just like a regular turbo if the 'Variable' part of the turbo is not functioning. All the vacuum lines are hooked up BTW and I've gone through all solenoids, no fault codes either.
I have an 89 Shelby CSX VNT with 58K miles on it. For the last 5 years it has been driven a total of 150 miles and was not driven at all for about 2-3 years before I bought it. I also have a 90 VNT/CP Shadow that has a LOT more off-line pep than the CSX does. The CSX seems to have quite a bit of lag but once the turbo spools up and there is boost, she comes on good and hard at about 4,000 RPM. The Shadow has almost no lag but does not pull as hard on the top end. Seems like the performance for the cars should be more similar since they have virtually the same engine.
Is there any way to test for a dead variable NT....and if the variable part is frozen from sitting several years, can it be worked free with just a carefull disassembly/reassembly?
Thanks to all in advance.
03-27-2005, 08:32 AM
My Ride: '92 IROC R/T
Engine: 2.2 135ci TIII 16v
How is your timing? My old '89 CSX #228 used to do what you're describing, along with overheating. Turned out to be a cracked head.
Is there a bigger turbo on there by chance? Like a TEC S60 VNT or a VNT 28? (I have both, and I've driven a S60 VNT car-little lag).
Or maybe a clogged cat.
So I'd first check the timing, double check all the lines, then the cat. I just recently (1 week ago) removed the exhaust housing off my S60 VNT to swap with a brand new one, and man was there carbon build up in there. You could see how the carbon was making the vanes stick a bit. When I moved the variable 'switch' with my hand, there was a bit of friction. On the new one, it moved smooth as silk.
'01 Maxima SE
03-28-2005, 11:22 PM
Yep, checked all that basic stuff. Timing as I recall was set at either 12 or 14 degrees advanced, no knocking and good power after the lag is overcome. It is a totally stock 58,000 mile CSX. No overheating, no smoke from tailpipe, no coolant in the oil. This car has no cat to clog so don't think that is it also great power in high RPMs so couln't be problem there. You did mention something I was curious about, opening the case and checking the movement of the vanes. I have two other rebuildable VNT turbos, one of which was brand new so it has all new vane assembly, dont know if I can just swap them or not. If I don't find an external problem I may open it up just to confirm that is not or is the problem. From experience, it might be better to just buy a new VNT outright rather than mess with trying to fix one myself.
03-29-2005, 02:40 AM
Hmmm.......wow, sounds like you do have a hard one here. Okay, hows the clutch? I know it's a low mileage car, but are there any signs of the clutch slipping? Since you've checked all the other things off your list, then it's probably the turbo. Anyone else want to give a stab at this?
'01 Maxima SE
03-29-2005, 11:57 PM
Good clutch. I can dump it on dry pavement anytime if I rev it up a bit to get over the spool hump. Not a clutch thang'
04-07-2005, 10:48 PM
My Ride: 88,89,90 Shelby's
Engine: T2's and a VNT
It's not the V that quits working..it's the 'T'.
Are you sure your Shadow is a VNT and not just a normal 2.5L Turbo 1? I guess you'd be able to tell by the tag on the bottom side of the hood. It would totally make sense if that was the case.
04-08-2005, 01:41 AM
VNT seems to have too much lag
Yes, I am quite sure the 90 is a VNT car, VIN# confirms it's 1 of only 27 Shadow VNT/CS cars built that year. The CS option was the same concept as the CS option on earlier Daytonas. Power nothing but a Turbo IV engine with stiffer shocks and rear disk brakes. It's a fun little ride, a lot like the 89 CSX/VNT but does not handle as well.
04-08-2005, 09:47 AM
Send me you phone number.... As a long term 89 CSX owner (2 in fact), I can probably explain it easier than I can write it.
steve911@charter.net
thanks
Steve A.
89 CSX 003
89 CSX 474
