VNT Help for VNT cars
Old 04-19-2005, 09:35 PM   #16
My Ride: 90 Shadow ES VNT
Engine: 2.2l 135 CI
Irony just bit me in the butt...
Now I am having a problem similar to GLHShelby...
Car has run 21 psi no problem
16 psi FWD/ND SBEC
3 inch exhaust
stage 2 ported head
ported intake
ported exhaust mani
underdrive pully
52 mm TB
VNT28 TUrbo
Magnecore wires
NGK plugs
ARP studs
180 deg T-stat
NO vac leaks at all
Just got it running...timing is set to 14 deg
Runs nice...all the way up to 12 psi and then I get cutout.
Nothing has changed since with the engine internally or with the head.
Swapped a ported intake (FM) with another during the rebuild (FM again)
Changed the waterpump
Changed all the vac lines
Changed all the intake/exhaust gaskets
Added a front mount
Changed TB gasket
retimed engine
All I can think of is the cheapie cap/rotor I got from advance auto (old ones were cracked and dealer was closed at the time) and maybe a bad pcv valve...
Thoughts?
p.s. didnt mean to hijack thread, just curious if issues are similar... ?
90DodgeVNT is offline
Old 04-20-2005, 03:43 AM   #17
Originally Posted by sdac_guy
You should have vacuum on the line to the top actuator nipple at idle. The larger bottom line should (and most likely does) have boost pressure under boost.
Uh, I had these bass ackwards here. The top is for boost & the bottom is for vacuum.
But for a good reference on how the VNT boost controls work & a sensibly drawn vacuum diagram see Donovans Dodge Garage Under the Turbo Tech section items #19 & #49.
Barry
sdac_guy is offline
Mobile Phone | Buy Anything On eBay | Loans | Myspace Proxy | Loans
Page generated in 0.36700 seconds with 13 queries
