VNT Help for VNT cars
Old 04-18-2005, 08:26 PM   #1
VNT or T1 preffered?
My Ride: 91 'Tona Shelby
i found a site that said the VNT allowed for faster spool up(almost no lag at all), and a lil more top end. true or false? and does that make it more powerful than the t1-2-3?
orion is offline
Old 04-18-2005, 08:58 PM   #2
http://www.xmission.com/~dempsey/shelby/t1t2t3t4.htm
I beleave that is what you want. Normaly people get rid of the VNT turbo to get more power.
Daniel Merrill
89acclaim is offline
Old 04-18-2005, 10:00 PM   #3
NO Democracy!
A VNT does allow for faster spool up. But, top end suffers due to the design of the VNT turbine section which is restrictive.
The design of the VNT doesn't make it more powerful... A T-II and a VNT are esentially the same engine except for the turbo. Comparing these two, you'll get more low end grunt (torque) out of the VNT and full boost will come on much quicker (12psi stock), but on the T-II... you'll get a bit more HP at that same 12psi at the expense of the low end. As the boost goes up, the T-II will make alot more power than the VNT would, but stock to stock, the HP difference is slight. My VNT will make 15psi of boost at WOTright around the 2,100 rpm mark. My friend's '89 T-II with a G-valve will make full boost (15 also) at more like 3,500 rpms.
A T-II is the most desireable to get as it is intercooled and has all the heavy duty drivetrain components to allow ALOT more HP. The VNT is the same, but the turbo just isn't good much above 15-16psi. I would rather have a VNT (T-4) than a T-I.
So what's the question for? You shopping for your next turbo Dodge? Anything that came intercooled from dodge (T-II,T-III, and T-IV) would be your best platform to start with as like I said, they got all the good hardware like forged crank, HD rods, etc... and better trany and brakes/suspension to boot.
DirectConnection is offline
Webbdesign | Car Credit | Loans | Personal Loans | Power Rangers
Page generated in 0.28758 seconds with 13 queries
