VNT Help for VNT cars
Old 04-24-2005, 10:32 PM   #1
VNT Question
Images: 1
Maybe someone can help.....I have a '89 CSX with a ND computer on it. When I reach 95mph, I get fuel cut, I boost only to 10psi and check engine light comes on. What could it be??
sleeping8t7 is offline
Old 04-25-2005, 04:53 PM   #2
My Ride: 89 Shelby CSX
Engine: 2.2 VNT
Look at vacuum hoses first. Always seem to be a problem with them. What code is set with check engine light ?
csxvnt257 is offline
Old 04-26-2005, 06:20 PM   #3
Images: 1
The code I get is a internal code, like a computer code. I forgot right now but it's a computer code.
Old 04-26-2005, 06:34 PM   #4
I think all modified SBECs will give a 53 code. Mine have so far, even though nothing is wrong with it.
tarkus1 is offline
Old 04-26-2005, 07:05 PM   #5
Will Martin's Avatar
My Ride: '92 IROC R/T
Engine: 2.2 135ci TIII 16v
'Sounds' like there may be a leak like Lynn said. Have you checked or replaced all the vac lines? Especially check the ones going from the solenoid to the turbo canister.
'01 Maxima SE
Will Martin is offline
Old 04-27-2005, 05:19 PM   #6
Images: 1
Ok, I'll check it out.
Old 04-29-2005, 02:50 PM   #7
The reason the modified computers throw the code 53 is because the programmer didn't take the time to fix the checksum error that occurs when you modify the code. No big deal. From what it sounds like, you may have a leak somewhere that is making the boost gage say 10psi, when the map is reading ~15.
Jckrieger is offline
Debt Consolidation | Mortgages | Xbox Mod Chips | Cheap Magazines | Debt Help
Page generated in 0.34737 seconds with 13 queries
