VNT Help for VNT cars
Old 06-18-2005, 11:27 PM   #1
VNT specs
My Ride: 87 shelby vnt dayton
Engine: 2.2L VNT w/bolt-ons
does anybody know the horsepower and torque specs for a VNt engine and a 2.5L turbo II? also was there ever a 2.5 liter VNT? and one last thing does anybody know how many 1990 lebaron GTC/VNT`s were made? THANKS!!!!
87shelbyVNT is offline
Old 06-19-2005, 12:35 AM   #2
gtc vnt
1/4: 13.310
vnt's were only 2.2's. about 250 GTC vnt's were built. (1990 only - 3 months production).
asless is offline
Old 06-19-2005, 01:06 AM   #3
Will Martin's Avatar
My Ride: '92 IROC R/T
Engine: 2.2 135ci TIII 16v
I have a 2.5 with a VNT. I'm in the final stages of bolting it all together. All that's needed is for me to put on the drivers axle and bolt back on the radiator, alternator, and intercooler. It's a 2.5l with a TEC S60 VNT, 2.5" exhaust, (TBI header to be added later), A-568 trans with Phantom Grip, FWDP 2.2 S3 cal, +20 injectors, adjustable fpr, alcohol injection, Poly Bushings mounts all around, yada-yada. I had to drop in the 2.5 as my 2.2 is getting built up with my Steve Menegon head. This should be torque heaven! I'll try to get it dyno'd before I blow it up! LOL I'm working for about 220hp/250tq.
'01 Maxima SE
Will Martin is offline
Old 06-19-2005, 10:29 AM   #4
My Ride: 85 GLHT, 87 ShelbyZ
I see lots of tire spin and no top end.
GLHNSLHT2 is offline
Old 06-19-2005, 11:16 AM   #5
Exactly. BUT if I wanted, I could put the SM head on there and that would free up some flow up top. And this is on my daily driver as well, I just need it to go to and from work (beating up on unsuspecting victims as well) . What will also help with spool time is I have a Fidanza aluminum fly wheel on it too.
GLHNSLHT2. You ever come up this way? Are there any tracks near you that you go to?
'01 Maxima SE
Old 06-19-2005, 12:19 PM   #6
My Ride: 90 Shadow ES VNT
Engine: 2.2l 135 CI
220 hp is all that you are shootin for?
I bet you will be much higher then that...
What psi will you be running?
90DodgeVNT is offline
Old 06-19-2005, 01:20 PM   #7
Well, the cal is set for 16-18, something like that. BUT with the S60 VNT, I should be at a higher hp level at 14psi than a reg. VNT would be. A maxed out VNT can go up to around 220-230hp before it's done so I should be higher than that. So okay, you caught me being modest! LOL But I don't want to assume where I'll be at until I can get it all tuned. The alcohol is a precaution because of the 2.5's ability to not like timing advance.
'01 Maxima SE
Buy Anything On eBay | Fuente De | 0 Credit Cards | WoW Gold | Cheap Loan
Page generated in 0.79860 seconds with 13 queries
