07-19-2005, 08:31 PM
My Ride: 91 Spirit R/T
Engine: TIII
As I understand it all that is really needed is a TII turbo with new coolant and oil lines and a grainger valve. I am unsure if the VNT boost control will work, probably not....Never tried to deal with it. Plug the two vacuum lines going to the VNT actuator. Wrap the VNT turbo in some plastic, keep it in a cool dry place incase you need to put it back on. Everything else should match up, exhaust mani, intercooler tubing. Might run into a glitch with the air intake?, it could be a different diameter than the TII, but those hoses are real easy to come by.
It wouldn't be too hard to do. Remove the head with manifolds, swap turbos and reinstall for the tough part.
