VNT Help for VNT cars
Old 07-27-2005, 06:27 PM   #1
top 5 "bang for buck" mods from stock vnt
I was curious on what mods were the best on a vnt car starting from stock. This could be anything,from mounts to air cleaners to tires/wheels. So what are YOUR top 5?
89CSX#17 is offline
Old 07-27-2005, 07:10 PM   #2
Will Martin's Avatar
My Ride: '92 IROC R/T
Engine: 2.2 135ci TIII 16v
1-exhaust
2-front mount aftermarket intercooler
3-S60 VNT
4-suspension/brakes
5-cal
(5.5-alky injection
'01 Maxima SE
Will Martin is offline
Old 07-27-2005, 08:48 PM   #3
My Ride: 1990 Lebaron GTC
Engine: 2.2L VNT
Exhaust
Boost Controller (to avoid overboost)
Cold Air Induction
Suspension
Computer
Those are mine for a STOCK vnt25. If upgrading to a better VNT then the S60VNT for sure.
Whorse is offline
Old 07-28-2005, 09:49 AM   #4
Hey Jason,
You're shorting yourself a spot! LOL If you had a good cal, it would control the boost. The only way you're gonna avoid overboost is to lay off the throttle.
'01 Maxima SE
Old 07-28-2005, 09:28 PM   #5
Engine: 2.2L VNT
Computer/Cal - Electronics if you will. With a proper wastegate control you should be able to control overboost, but the Calibration is essential. Guess you could say I used the wrong words :P
Whorse is offline
Old 07-28-2005, 09:41 PM   #6
Okay, so go ahead and buy my VNT28! LOL That's a start.
'01 Maxima SE
Old 07-28-2005, 09:54 PM   #7
Engine: 2.2L VNT
A bit off topic, but how much HP can a 28 handle vs. a 25, and does it breathe any better even though it's the same housing?
Whorse is offline
Old 07-29-2005, 12:05 AM   #8
Not too sure anyone has ever done back to back testing. But because of the larger wheel, it would put our more hp at the same boost levels than a stocker.
'01 Maxima SE
Old 07-29-2005, 02:13 AM   #9
Engine: 2.2L VNT
I was looking at a thread in the exhaust section about the VNT muffler, and after seeing the internals and how much went into controlling the backpressure, I'd have to agree with Will that a good Calibration is an essential upgrade for a higher perfomance VNT, especially with an exhaust upgrade.
+1
Whorse is offline
Old 08-28-2006, 03:37 PM   #10
I put a T2 turbo on mine.
mest VNT mod ever.... lol.
TurboShadowES is offline
Mortgages | Car Loan | Loans | Free Image Hosting | Car Finance
Page generated in 0.36817 seconds with 13 queries
