VNT Help for VNT cars
Old 07-31-2005, 09:36 PM   #1
ok need help
i just got a 1990 dodge shadow es turbo i think it has a vnt not sure can anyone help me find out plz
iwantsaturbo is offline
Old 07-31-2005, 09:41 PM   #2
My Ride: GLHS Charger
Look at the wastegate can on the turbo. If it has two nipples with lines going to it, it's a vnt turbo. Only one nipple on the wastegate can, it's not.
MVaughn is offline
Old 08-02-2005, 11:13 PM   #3
shadow vnt
1/4: 13.310
the 8th digit in the VIN will be a 'C' if it was a factory vnt car.
asless is offline
Old 08-03-2005, 01:03 PM   #4
My Ride: Omni and Daytona
any stickers on the car that says VNT INTERCOOLED ? or TURBO INTERCOOLED ?
Cornflakes_GLHT is offline
Old 08-03-2005, 02:56 PM   #5
My Ride: 1990 Lebaron GTC
Engine: 2.2L VNT
The hood bulge says Intercooled VNT if it's stock. Also check inside the door jams on the driver side.
What does the gauge cluster look like inside, how many nipples on your turbo outlet and wastegate, and how big is the actual turbo. The VNT is noticeably smaller than the Garret T2's.
Whorse is offline
Old 08-04-2005, 11:12 PM   #6
My Ride: 87 shelby vnt dayton
Engine: 2.2L VNT w/bolt-ons
does anybody know how much boost i can run out of my 2.2L vnt with out overspolling it? would it make any sense to put a boost controller on it? also where do i adjust my boost at?? thanks Kevin
87shelbyVNT is offline
Old 08-04-2005, 11:14 PM   #7
hey asles i got a question for ya! how could i tell if my car was a factory t2 intercolled car? thanks
Old 08-04-2005, 11:20 PM   #8
Talk about hi-jacking a thread. Start your own thread. If you have problem doing it, pm me.
MVaughn is offline
Old 08-05-2005, 07:59 AM   #9
Engine: 2.2L VNT
Easiest way to tell is to look at your vacuum diagram under the hood if the original is still there (which it should be). If the solenoids list 2 VNT solenoids, it's a VNT, if not (and it's intercooled) it's T2
Whorse is offline
Old 08-05-2005, 09:23 AM   #10
To be clear on the the factory turbo engine choices for the 1990 model year ...
If you have a stock factory intercooled 2.2 in a 1990 model year car, it is a VNT. 1989 was the last year for the T-II.
The only other turbo motors in 1990 were the 2.5 T-I.
Some folks have added factory type intercoolers to a 2.5 T-1 though and they "look" like a stock install.
As stated here previously, if the wastgatge actuator (vane actuator on VNT) has 2 nipples it is a VNT turbo, if it only has one nipple it is the 2.5 T-I.
Also, as was said here previously, for 1990 a C in the 8th digit of the VIN is for the VNT, while a J in that position is for the 2.5 T-I.
Note, in the Factory Service Manual for 1990, the VIN decode info mistakenly says C is for the T-II instead of T-IV for the VNT. Allpar has carried that same mistake over to their site as well.
Barry
sdac_guy is offline
Old 08-05-2005, 10:27 AM   #11
vnt id
1/4: 13.310
As noted, in 1990 the only 2 turbo motors were 'C' - T4 and 'J' - T1. On g-bodies all T4 (vnt equipped cars had the vented rear rotors. Not sure about the P bodies. VNT's had black valve cover and intake. The vnt car will have a metal lower IC tube with hose on each end to connect to the IC and turbo. The vane actuator is verticle and has the two hose barbs. If you have seen any other TD wastegate can, you will immediately see this is different. The vnt cars have 4 selinoids over on the passenger inner fender. Three in a row and one on the strut tower. The intake manifold has a charge temp sensor whereas the T1 iintake does not. I only ever ran mine to 16 psi or so (bled the top actuator line). Was good for mid 14's on street tires. If you hit overboost on a vnt you will notice it is different. The vnt SBEC will allow spikes into OB for a second without kicking in. When it does, it is not a big 'wham' like the normal ob shutdown, it is more like a stutter out of the engine. The vnt will have a 568 trans whereas the T1 may not. (I have seen a couple of 90 T1's and they both had 523's although I have read that the 568 did come on some T1's). I gave up on the vnt thing and changed over to a T2, easier to get more boost, easier to get parts. The vnt is only an advantage on the street with the quick spool. If racing you launch at higher rpm and stay there, negating any benefit the vnt may have had. But - if there was a vnt readily avialable , that would make 25 psi, and live I would defintely reconsider. I am waiting for someone to adpt the bigger deisel vnt turbos.
asless is offline
Old 08-05-2005, 03:35 PM   #12
Will Martin's Avatar
My Ride: '92 IROC R/T
Engine: 2.2 135ci TIII 16v
I've been looking at those. I'd like to get my hands on one just to try it out. I think I could find a way using solenoids. They have some "E" style VGT/VNT turbos out there that are good for the 250-400hp range. If I could only find one.....
'01 Maxima SE
Will Martin is offline
Mortgages | Loans | Mortgages | Ringtones | Apply for Credit Card
Page generated in 0.40547 seconds with 13 queries
