08-11-2005, 10:34 PM
My Ride: 1990 Lebaron GTC
Engine: 2.2L VNT
I swapped my VNT IC for an Audi 10V unit, which is known for it's horrible flow, and it seems to be giving me a bit more power, so I'm assuming that if the Audi unit flows better, that the stock unit is very restrictive.
The stock BOV is on the airbox in 1990 cars, and it isn't bad for stock boost level applications. That said, I wouldn't use it over 13PSI, and if you want to run 20psi you'll need a VNT28.
Best bet with the VNT is to run a boost controller and upgrade your exhaust (need to control the overspooling), a large well placed intercooler that has a low pressure drop, and a good cold air induction (biggest performance boost I had was from CAI).
