09-26-2005, 11:37 PM
#20
Originally Posted by frostburner
i disabled it last night.. and still have issues.. the car is surging now.. if i go wot itll boost but then pull timing and hesistate then back to boosting.. so the car sort of bucks.. keep in mind i have 100 oct gas in the tank and it should not pull timing or anything.. car is throwing no codes either..
The bleeder valve was not even open! I put that in the car when I redid everything in the car 3 years ago. Steve probably forgot about it because he does not mess with that kind of stuff and just forgot to mention it. I put it in so I could up the boost in the future. I did try it a few times but was too touchy with that cars setup. Boost was spiking too much and not staying constant so I just left it closed. Unlike my CSX I was able to control it better.
I never told you that the car was stock, maybe Steve did! But you knew the car had a 2 1/2" exhaust, 20% injectors, AFPR, CSX recaro interior and probably a few other minor items I cant remember right now. It was meant that the engine was not heavily modified cam, pistons, turbo, head ETC. If you know what you are doing a bleed is not a big deal.
So you never raised the boost in your other cars!
Patrick Pedroza
Anaheim, CA.
"86" GLHS # 35 GT35R to go in soon!
"89" CSX #42 (217,000 orig miles)
"04" SRT-4 stage 2
