Warning: parse_url(http://) [function.parse-url]: Unable to parse URL in [path]/includes/init.php(293) : eval()'d code on line 95
G-valve a vnt - TurboDodge.Com - Turbo Dodge forum for Turbo Mopars, Shelbys, Daytona, SRT-4, PT Cruiser, Omni and more!
VNT Help for VNT cars
Old 08-09-2005, 02:54 PM   #1
G-valve a vnt
My Ride: 1999 Integra GSR
Engine: 1.8 DOHC VTEC
K, doesnt seem ike this is talked about much, is it because it can't be done or no one does it? How is it done!
89CSX#179 is offline
Old 08-09-2005, 03:16 PM   #2
Will Martin's Avatar
My Ride: '92 IROC R/T
Engine: 2.2 135ci TIII 16v
It's not talked about much because it's 'almost' useless. What I mean is you take a turbo that's already "out of it's league" (like you noted in another post), and up the boost. If you can get it controlled to around 15-18 STEADY psi and it's in good shape, then you should be okay. If not, then you're gonna spike high, especially when it's cooler temps outside, and eventually wear out the bearings then boom! LOL If you want to do it anyway, just put the g-valve on the TOP VNT canister nipple line. Make sure you turn it VERY SLOWLY until you achieve desired boost.
'01 Maxima SE
Will Martin is offline
Old 08-09-2005, 04:34 PM   #3
well Im only looking for 14psi, and the other guy was askin for 20psi, 14psi on the vnt is very doable
Old 08-09-2005, 04:35 PM   #4
top vnt line then to where?
Old 08-09-2005, 05:10 PM   #5
Then back to the nipple. It's like this:
<SOLENOID>...<VAC LINE>...<G-VALVE>...<VAC LINE>..<TOP VNT CAN NIPPLE>
'01 Maxima SE
Old 08-09-2005, 05:15 PM   #6
Images: 1
Check here... www.thedodgegarage.com/turbo_vnt_bleed.html
sleeping8t7 is offline
Old 08-09-2005, 05:32 PM   #7
k, got it, id like to thank everyone who made this possible, my dad's credit card, and Will's vnt knowledge
Old 08-09-2005, 09:22 PM   #8
My Ride: 1990 Lebaron GTC
Engine: 2.2L VNT
I have a post on my site about another way to do it if you like. Involves putting a restrictor on as well to control the spike, but it's pretty close to the one on Donovan's site.
Whorse is offline
Old 08-09-2005, 11:05 PM   #9
where yur site?
Old 08-09-2005, 11:59 PM   #10
k Whorse, i found the pics of the solinoids, now solinoid 3 is the line that runs to the top nipple of the actuator correct, its hard for me to tell where it goes cuz it gets lost in all the other ones
Old 08-16-2005, 07:23 PM   #11
My Ride: 90vnt daytona shelby
Engine: 2.2 L
Images: 4
How come my turbosmart MBC doesn't work on the vnt??
ironbird720 is offline
Old 08-16-2005, 10:22 PM   #12
Engine: 2.2L VNT
Correct. Solenoid 3, the one you want, goes to the top of the actuator, and one goes from the turbo outlet to the solenoid.
Whorse is offline
Old 08-21-2005, 01:41 AM   #13
so is 14 psi ok for a stock fuel system?
Old 08-29-2005, 05:21 PM   #14
Engine: 2.2 L
Images: 4
I sometimes get up to 18 psi when it's cold before it cuts out and the A/F guage reads on the last 2 or 3 bars in the rich with stock injectors.
Old 09-24-2005, 04:14 PM   #15
i was investigating my shadow today to try to fix my tach adn radio and i found a bleeder valve behind the ash tray so u can change boost insid ethe engine bay.. now the previous owners said they didnt modify the car and just kept it stock relaly.. so i have no idea how taht got..its set up like the diagram in teh dodge garage
frostburner is offline
Credit Card | Mortgages | Mortgage insurance | Mobile Phone deals | McDonalds
Page generated in 0.56989 seconds with 13 queries
