08-09-2005, 03:23 PM
My Ride: '92 IROC R/T
Engine: 2.2 135ci TIII 16v
You my friend, have a definite vac leak. Lines to check; throttle body, MAP, solenoids, turbo connections, and manifold. What probably happened was the extra boost pressure took off a line, you just have to find it.
'01 Maxima SE
