Old 10-26-2005, 10:07 AM   #1
compression with stock 2.2L pistons?
what 'should' the comrpession be with stock 2.2L pistons?
shelbyplaya is offline
Old 10-26-2005, 10:22 AM   #2
My Ride: 1985 Shelby Charger
Engine: 2.2 T2
I believe the 2.2l 16V turbo is the same as the 8V 2.2l turbo, 8.1:1
crazy1eye is offline
Old 10-27-2005, 09:46 PM   #3
cr
My Ride: shelby lancer 2.5hyb
shelbyplaya
Do you mean the 16v head with stock 2.2L pistons? If so, the 16v 2.0l head has a larger comb chamber volume and therefore will lower it. I went through a massive data collection and calculated it at close to 8.0 to 1. But I decked the block .012 and the head .010" to get this. It may even be lower because I am having no detonation problems with mid grade gas, I THINK.
andy
lancer402 is offline
Old 10-28-2005, 10:08 AM   #4
yeah i got a set of 2.2L 8v forged pistons. i wanted to get them cut for the extra valves of the 2.0 16v head. i plan on running onley about 15-18psi to start things off.
Old 10-19-2006, 10:17 AM   #5
My Ride: '92 Daytona Iroc
i need to bring this up, as i'm playing with the idea of going hybrid by the end of 2007
so you say, if i go 2.2 crank with 2.2l 8v pistons (forged of course) i would be close to 8.0:1 CR?
i have done a couple of searches and haven't found the answer to this questions:
2.2 crank with 2.2 pistons AND stock rod height -> possible?
btw: 2.0 neon head!
Austrian Dodge is offline
Old 10-20-2006, 01:05 AM   #6
My Ride: 2004 SRT4
Engine: 2.4
Feedback: (-1)
Use the forged aftermarket Tlll pistons. They already have the correct valve relief. The stock ones will have your compression ratio closer to 9.0. The aftermarket ones have a deeper dish on top of the piston. I am not sure that regular forged 8v pistons would work. I have a set of stock Tll pistons I can mock it up and measure if you need. It would probably be on sunday before I can do it.
Andre Parker is offline
Old 10-20-2006, 04:59 AM   #7
andre, that would be great if you can do that!
i'd like to have something around 8.0 : 1, and of course using my existing 8v pistons would help me keeping the cost factor down, but then again, if the tIII pistons are helping me more, then i'd go for them!
lmk
Old 10-20-2006, 11:37 AM   #8
My Ride: 88 CSX-T
I dont know if this helps or not. I cc'd my set up. I have a 2.5. I have forged JE pistons for a 2.5(2 reliefs) 2.5 head gasket. My 2.0l head has been milled about .007". I cam up with 8.43:1 with a virgin head I got 8.30:1
turbometh is offline
Old 10-25-2006, 05:37 PM   #9
andre, any news?
Old 01-01-2007, 12:16 AM   #10
so I'm still lost. 2.2 crank and w/ stock rods, neon head gives me how much compression with tIII stock pistons and the forged pistons available from FWD?
ForceFed Wraith is offline
Old 01-01-2007, 04:59 AM   #11
My Ride: '88 Shelby Z TII
I'm just interested to know if the 2.2 8V pistons will work with the head...I've heard/read the 2.5 ones will...
I have a set of psitons that are supposed to yeild 8.2:1 compression on an 8V set-up using a G-head.
Reaper1 is offline
Tutorials | Myspace Layouts | Mortgage | Loans | Credit Check
Page generated in 0.37081 seconds with 13 queries
