12-28-2005, 02:02 PM
My Ride: 2004 SRT4
Engine: 2.4
You can snag a 58mm from a mini van which should be more than enough. The bigger the TB, then you may be trading some low speed velocity at low rpm for more flow ability at mid and top end. It will all depend on your set up, but really if you already have a 52mm, and your building a primary street car first and track car second, you'll be just fine with what you already have. You can get 65mm ford mustang TB's pretty cheap, but have to make an adapter for our ais motors. You should be able to bolt on our tps sensor. For simplicity, I would use the 58mm minivan one if you really feel you need bigger than your 52 though.
