01-30-2006, 08:03 PM
#18
My Ride: Whatever runs
Engine: 2.7tt, 2.0, 2.5, 2.2
Originally Posted by 8valveprick
I plan on running a DSM engine harness and ECU.
PROS: - easy datalogging, I already use the software for datalogging my Colt.
- can use SAFC
- can later use DSM link for full manual control of engine
- CHEAP, at least for me
I already have a parts car w/ ECU and harness. I have an extra SAFC. All my friends that are smarter than me are familiar w/ the DSM stuff. I won't have to pay for a custom cal and when I make changes to the car I won't have to send my computer back for changes. My only real expense will be a Mass air translator ($200) since I will be using a blow through GM Mass air(free). I don't know what a custom cal + 3 bar map will cost, but I'm sure it's more than $200.
CONS: - I will have to adapt a DSM cam angle sensor
- having to wire it in
As far as I know all I need is the injector harness, tps, coolant temp, knock sensor, O2 sensor, and coil pack. I already (with help from friends) wired my Colt this way and it wasnt bad at all. I would have to add all the same sensors to the 16 valve setup to run the dodge electronics anyway.
Are you doing a hybrid? Why not use the DSM head, intake mani. and exhaust man. too. Do the head bolts/bores line up? You save a bundle and the part are CHEAP. Then the CAS will be setup right from the start. Then you could go with DSM injectors too and just tune it like a stroker DSM.
