Old 01-28-2006, 01:19 PM   #1
You'll hate my next idea.
I plan on running a DSM engine harness and ECU.
PROS:
  1. easy datalogging, I already use the software for datalogging my Colt.
  2. can use SAFC
  3. can later use DSM link for full manual control of engine
  4. CHEAP, at least for me
I already have a parts car w/ ECU and harness. I have an extra SAFC. All my friends that are smarter than me are familiar w/ the DSM stuff. I won't have to pay for a custom cal and when I make changes to the car I won't have to send my computer back for changes. My only real expense will be a Mass air translator ($200) since I will be using a blow through GM Mass air(free). I don't know what a custom cal + 3 bar map will cost, but I'm sure it's more than $200.
CONS:
  1. I will have to adapt a DSM cam angle sensor
  2. having to wire it in
As far as I know all I need is the injector harness, tps, coolant temp, knock sensor, O2 sensor, and coil pack. I already (with help from friends) wired my Colt this way and it wasnt bad at all. I would have to add all the same sensors to the 16 valve setup to run the dodge electronics anyway.
8valveprick is offline
Old 01-28-2006, 03:56 PM   #2
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
Sounds like a good idea for you. Should be easy. No crank angle sensor? I hear MAF fuel injection is alot easier/more forgiving to tune..
Una is offline
Old 01-28-2006, 04:11 PM   #3
My Ride: 1987 Daytona Shelby
Engine: 2.5 16v
Could you not use the neon Cam angle sensor for that? or adapt it to the work off the cam?
Garret is offline
Old 01-28-2006, 06:05 PM   #4
My Ride: No slicks Omni
We have a local DSM guy (Talon) who was first to
run in the 10's with stock lower end. Pretty stout
stuff, especialy in that flyweight.
russ jerome is offline
Old 01-28-2006, 09:30 PM   #5
I'm wondering that myself. On the DSM you adjust timing by moving the cam angle sensor, the one on the Neon head is stationary. I took a long look at it today and I don't think it will be hard to make an adapter. I just have to remove the magnet and replace it w/ an aluminum piece, and put a slot in it to turn the DSM unit. Then I have to make a cover plate w/ the right size hole so the sensor's O-ring will seal.
Old 01-28-2006, 09:32 PM   #6
Just thought of something else. Are Dodge injectors high or low impedence. I think DSMs use low.
Old 01-28-2006, 10:30 PM   #7
Engine: 2.5 16v
well why not use the DSM injectors?
Garret is offline
Old 01-28-2006, 11:23 PM   #8
Una
Engine: 2.5L Turbo
Low impedance
Una is offline
Old 01-29-2006, 08:59 AM   #9
ohiorob's Avatar
My Ride: 83 shelby charger
Engine: 2.4 DOHC
1/4: 10.066
Won't the cam angle sensor be turning the wrong way on the dodge head ?
by the way I think you got a good idea there.
ohiorob is offline
Old 01-29-2006, 05:18 PM   #10
Una
Engine: 2.5L Turbo
How does it matter what way it turns? It just generates pulses.
Una is offline
Old 01-29-2006, 08:53 PM   #11
They don't fit. They are shorter and fatter.
BTW: The only reason I wrote that you'd hate my idea is that every time I see DSM on here somebody gets all worked up and has to argue how much better Dodges are.
Old 01-29-2006, 09:11 PM   #12
They should be turning the same way. They will both be on the end opposite the cam gears and if my memory is correct both motors spin the same direction. Clockwise when facing the timing belt side of the motor.
My DSM friend told me it would matter to the computer. I didn't ask why, but he knows his DSM junk.
Old 01-29-2006, 09:20 PM   #13
Engine: 2.5 16v
Well they clearly are better than DSMs, but owning a TD is all about stealing parts from a better car to use on ours
Garret is offline
Old 01-30-2006, 09:10 AM   #14
My Ride: Omni
Engine: 2.2 liter 16V hybrid
If you know DSM computer, it's not a bad idea.
For my 16V, i'l go with flashable smec, much more easy to do, but no dataloging available for now..maybe....
Guillaume
guidsm is offline
Old 01-30-2006, 10:37 AM   #15
Una
Engine: 2.5L Turbo
Guillaume
Datalog with an OTC 4000E hooked to a laptop.. That's what Paul at TU did on the Dyno..
Una is offline
Credit Cards | Mortgage | Free Advertising | Secured Loans | Advertising
Page generated in 0.47215 seconds with 13 queries
