01-31-2006, 12:05 AM
My Ride: 94 Sundance Duster
Engine: 4 Cyl 2.5L
After reading some of the threads on here i think i may end up getting a sds stand alone engine management systen I was thinkin this one would work best for my aplication:
"The 4F system, shown above, controls fuel delivery and ignition timing on 4 cylinder engines to 9750 rpm (15,000 optional). Its crank triggered, direct fire coil pack replaces both distributor type and OEM distributorless ignitions. It is programmable in 250 rpm increments with 64 boost retard locations available for turbocharged engines and ignition retard under nitrous activation.
The standard F delivers a powerful, long duration spark and is suitable on engines with specific power outputs of up to 200hp/liter. With the addition of an MSD DIS, power levels can exceed 400hp/liter. The 4F comes complete with coils and crank trigger. Fabrication of a crank sensor mount and installation of trigger magnets is required.
Base system prices USD: 4F as shown above- $1311, 4F for MSD DIS-2 no coils or driver $1148, 4F to drive OE waste spark coil pack $1238
The only question i have about this is does the last one in bold allow use of the stock neon coil packs or do all 3 versions come with their own coil packs?
