Old 02-05-2006, 01:03 AM   #1
Is an updated cal or larger injectors needed with a 16v conversion?
I'm not doing a 16v conversion yet but I am looking into buying a recaled computer, but I am wondering if I'd need a different cal after going to 16v? I'd think it's possible that I'd need more fuel going in to compensate for the increased flow of the 16v head or am I completely wrong? I could see it going either way so can someone clarify? Thanks.
DaytonaTurbo87 is offline
Old 02-05-2006, 01:12 PM   #2
My Ride: Omni
Engine: 2.2 liter 16V hybrid
For a cheap solution you can use D-cal and modify fuel/spark for you 16V. That what i will do this spring. The good this is you don't need to rewire anything and the smec have a good reliability.
Also keep an eye on the this section, i will post the binary as soon as my setup will run.
guidsm is offline
Old 02-05-2006, 04:56 PM   #3
My Ride: '89 Horizon
Engine: 16v 2.2 Hybrid
Larger injectors are a must. As far as your electronics go, I don't know when it's necessary to go with something better. Sorry to hijack, but this relates... What would be the best and most cost effecient engine management for a hybrid setup running around 350 hp? I'm looking at a megasquirt II for this summer.
Hodgie
hodgie is offline
Old 02-05-2006, 05:09 PM   #4
My Ride: Omni
Hodgie
There 3 bar +40% injector binary to begin your cal in D-cal.
Megasquirt are also sa good cheap stand alone. MS1 whit spark uploaded to ecu can provide you same option than MS2. ( MegasquirtnSpark-extra )
U can use the stock pickup coil to take the ignition event.
guidsm is offline
Loans | Auto Loans | Auto Loans | Loans | Credit Cards
Page generated in 0.42325 seconds with 13 queries
