04-27-2006, 08:00 PM
#62
My Ride: Whatever runs
Engine: 2.7tt, 2.0, 2.5, 2.2
Originally Posted by tkelly27
non CB 2.2 block with non CB 2.2 belt. I think the CB and the 2.2 non CB have nearly the same height, could be wrong. The difference between cam gears is neglidgable compared to the slack in the belt. Compared the square tooth 8v to the round tooth 8v and they are simmilar in size too. Also, you can not use the neon cam gear it has a different tooth count, I spent all morning counting, then I read 89acclaims post  Does anyone make cut to length spark plug wires that'll fit the stock distributor? The distributor fits in the stock location OK, (it'd fit even better if my dad would let me grind in the garage : ( ) but the wires are way to short to reach down into the holes. I would not put the dist on the end of the cam unless I absolutely had to, looks like a lot of machining and a lot of oil sealing issues. If you can competently describe to someone how to machine a cam to accept a distributor (or machine it yourself) you can make an intake that will accept the dist in the stock location. Seems like its going to be a hundred years before I ever get enough money and free time to do this.
*edit* reread 89acclaims post, With the significantly shorter deck height, mayby I'll hit up the junkyard and find a 2.0/2.4 timing belt. If that belt fits I'd just need to find a common block with round toothed gears to stick this head onto and everything would be peachy.
You can get a set of custom wires for $70 or make a set yourself by picking and choosing wire sets that are of compatible size and trimming accordingly.
