10-29-2006, 06:32 PM
Hybrid Booster
My Ride: 89 voyager van
Engine: hybrid dohc 16v 2.5l
I used an 1/8 drill bit,so .125''. I haven't had oil pressure loss problems,but I don't rev mine as hard as some,only sometimes to 6k.I blocked all the bleeds in the cam caps,and for drain backs I use two #12 fittings monted as low in each corner of the rear of the head as I could.
Oil pressure is normaly hot 20psi at the crank and 16psi at the head.I have seen it idle at the head as low as 8psi when stink hot after long hard trips on hot days,or really warm city driving.Cam journals looked fine last I looked.
This was using Mobil 1,0w50.I drive year round,so I see ambient air temps around -35c to +35c.
