Old 11-03-2006, 12:20 AM   #16
My Ride: No slicks Omni
Originally Posted by Turboweasel
so everything should work then right?
It "should", minor tweeking on your part no matter the head.
See no major hurdle in the Avenger head other than the obvious
changes mounting a 16v on a dinasaur 8v.
russ jerome is offline
Old 11-03-2006, 01:18 AM   #17
I would like the exhaust up front, ala Honda. Routing to the back isn't a big deal, it just goes under the oil pan. That might be an issue if you car is really low to the ground, then a custom oil pan would be needed with a hump in the middle to clear the exhaust.
Old 11-12-2006, 09:37 AM   #18
My Ride: 04' SRT-4
Engine: 2.4 Turbo
This maybe a little out there, but to me it seems the neon head would make more power during acceleration. The fuel and exhuast is flowing with the pull of the car, as opposed to flowing against it. Speaking of honda's they went to the same design as a neon in there K-series motor and make great power. Just my 2 cents.
Mr2.4T is offline
Old 11-12-2006, 03:37 PM   #19
Yeah, thats right, never even clued in, exhaust in the back, intake at the front. Makes more sense for exhaust routing in our ever shrinking engine bays, hood lines and lower cars.
Old 11-12-2006, 06:50 PM   #20
I dont think an "internal" combustion engine cares what direction
it points under acceleration. Likewise a fuel rail at 80psi doesnt
care what direction up/down is or braking force. A turbine jet
would be a different story I would guess.
Old 11-15-2006, 10:10 AM   #21
My Ride: 04' SRT-4
Engine: 2.4 Turbo
Good point. I guess that blows my theory out of the water.
Mr2.4T is offline
Old 11-15-2006, 10:26 AM   #22
another thing you need to worry about is that if you put the avenger head on then the turbo is going to be sitting where pretty plug wires like to poke out of the distributor on a normal 8 valve 2.2/2.5....... unless of course you use coil packs..... or mount the distributor on the end of the head
XxhorizonxX is offline
Old 11-15-2006, 02:50 PM   #23
This is probably going to sound stupid, but to avoid any major melt downs would coating, or adding a heat sheild help. I realize those divert a rather minor amount of heat when talking about being so close to plastics, but could combining them help out much. Or how about a custom header that would put the turbo over the trans? It would reduce the amount of heat directly in contact with the distributor and wires. That's my $.02 atleast, I'm sure there are more efficient ways to do this though.
-Joe
joker5k1 is offline
Mobile Phone | Meeting Rooms | Discount Magazines | How to Camp Out | Loans
Page generated in 0.38888 seconds with 13 queries
