12-09-2006, 04:20 PM
#16
obstacles
My Ride: 83 shelby charger
Engine: 2.4 DOHC
1/4: 10.066
#1 intake curves in at bottom and the tb will not bolt up, it hits the trans.
so i chopped the end off and one off an old turbo I intake, monday i'll take it up the road to get welded.
#2 the oil filter spins on an oil cooler which is under the pass. axle. the coolant lines from the oil cooler interfer with the inner cv . should be an easy fix.
12-09-2006, 05:21 PM
#17
My Ride: 89 turbo van 5-speed
Engine: 2.5 turbo
need a dist kit for that project , let me know rob
12-10-2006, 08:34 AM
#18
Engine: 2.4 DOHC
1/4: 10.066
no thank you, I got two of my own. Doing anything to your van this winter?
12-10-2006, 08:46 AM
#19
Engine: 2.4 DOHC
1/4: 10.066
Originally Posted by crazymadbastard
Sweet project!
What are your plans for electronics?
I'll be putting a dist. on the side of the head and going with a dohc cal. from Cindy.
12-11-2006, 09:12 AM
#20
Engine: 2.5 turbo
pulled out the tc motor and put back in the 2.5 hybrid one more time and working on the front end to get it to set lower. and then it will be going to the body shop to get choped. I put your cal on my computer and used it on the tc motor and wow it flys , but the motor is coming out just because there are so few of them out there.
12-31-2006, 06:10 AM
#23
up date
Engine: 2.4 DOHC
1/4: 10.066
motor and tranny in, hopefully for good. all mounts done. wiring done. working on mounting the stock SRT IC. the van should be done by the end of january or at least drivable. pics soon.
01-01-2007, 11:44 PM
#27
My Ride: 93 Sundance Duster
Engine: 3.0L V-6
was looking for a good home for a srt-4 motor i have and i did.
made a deal with Chuck Green for his clean 89 mini.
pics and info as i go along.
hell yea!
01-06-2007, 05:12 PM
#28
My Ride: 89 Spirit ES
Engine: 2.5 STD TII 20psi
Well it looks to be almost done. Here are more pics for Rob. He did an excellent job on it!
[IMG]http://www.****************/forums/photopost/data/647/medium/IM006373.JPG[/IMG]
[IMG]http://www.****************/forums/photopost/data/647/medium/IM006372.JPG[/IMG]
[IMG]http://www.****************/forums/photopost/data/647/medium/IM006374.JPG[/IMG]
[IMG]http://www.****************/forums/photopost/data/647/medium/IM006369.JPG[/IMG]
[IMG]http://www.****************/forums/photopost/data/647/medium/IM006376.JPG[/IMG]
[IMG]http://www.****************/forums/photopost/data/647/medium/IM006378.JPG[/IMG]
If anyone wants pics of something in particular or just more I'll post more up. I can take a pic of anything else to help everybody out, if that's okay with Rob.
Good work, Rob! :nod: Can't wait to take all 3 vans to the track in April.
01-06-2007, 07:37 PM
#29
My Ride: 85 GLHT, 87 ShelbyZ
So it can sit in the garage and rot?? Just a question.
01-06-2007, 07:48 PM
#30
My Ride: '88 Shelby Z TII
You said something had to be done to the intake, but I don't see what it was. I saw that the T-body was hitting the tranny, but beyond that how was that solved. Also, what tranny are you using? If it's an A413, how?
