01-04-2008, 08:58 PM
#188
Re: Electronic Distributor Adapter
My Ride: '90 Voyager
Engine: 2.5 16V Twin Mitsus
What's in the pics is what is used for hybrid, ngc, and non-ngc. Only difference is the program that I put on the chip.
So far I think I've gone through five different ways of decoding the 2.0/2.4 cam and crank. Each one worked on the bench and not on the car. I'm leaning toward noise as a possible reason for it not working. Right now I have it outputting a pulse when it sees a valid TDC crank signal, but the pulses come out longer than they should be or in completely wrong places. There are also pulses that are correct, at idle, there are almost no wrong pulses. I'm working on the serial interface so I can have it tell a computer when any of the inputs change and then graph it so I can see exactly what the adapter is getting as an input. I don't see how noise can be an issue, though, since I'm using the exact same hardware in my hybrid adapter which has been running for a little over 100 miles on my 2.5.
