Old 05-19-2008, 01:36 PM   #256
Re: Electronic Distributor Adapter
My Ride: '90 Voyager
Engine: 2.5 16V Twin Mitsus
We run a Yamaha WR450, 450cc single cylinder. Most other teams are running the big 4 cylinders (600cc). The light car wasn't a really great one, wasn't rigid enough. The frame sat in the back of the room for a couple years and got chopped up and scrapped last year.
turbo.shaft, your adapter is on its way. I kind of guessed for length on the crank sensor wire, all I've got setting around are SRT-4 motors. Remove the coil, connect the green and gray wires to their respective coil wires, connect the ground wire to the body, plug in all the sensors and hep wires, and you should be good to go. Hopefully.
90TurboVan is offline
Old 05-20-2008, 12:12 AM   #257
My Ride: '88 Shelby Z TII
Cool...interesting choice. The only attempt we ever made was with a 600cc turboed engine...our frame was WAY overdesgined and heavy. It was rigid though! LOL. After that we went the hybrid route...sometimes we're glad we did....then there are those other times...:P
OK..ebough thread jacking for the moment...I'll try and post pictures tomorrow!!!
Reaper1 is online now
Old 05-20-2008, 07:46 PM   #258
My Ride: 88 Plymouth Reliant
Engine: 2.5L T2
has this been tested on your motor yet?
this works for the HEP driven hybrid too?
Brian
Aries_Turbo is offline
Old 05-20-2008, 09:44 PM   #259
My Ride: 86 Laser XT
Engine: 2.2 turbo
Images: 2
this could be cool! Easily doable on my part with a junk yard full of neons =)
Old 05-20-2008, 09:49 PM   #260
Hybrid (stock distributor on a common block with a 16 valve head) is tested and working on two cars. Pre 2003 2.4 will be tested when turbo.shaft gets his adapter.
Old 05-21-2008, 12:30 PM   #261
Engine: 2.5L T2
sweet, ill get out the protoboard and grab a coilpack. thanks
Brian
Old 05-22-2008, 10:58 PM   #262
Excellent! This is the one I'm waiting for.
Carlos
lotsaboost is offline
Old 05-24-2008, 01:47 AM   #263
90TurboVan, I have put up some pictures of our FHSAE car in another thread. Check them out!
ERAU Formula Hybrid team needs some luck!
Old 05-24-2008, 06:18 PM   #264
Engine: 2.5L T2
btw, are you going to be making these for regular purchase?
Brian
Old 05-27-2008, 12:25 PM   #265
I will be, if all goes well. turbo.shaft, did you get it yet? Sent it last Monday...
Old 05-27-2008, 07:57 PM   #266
Engine: 2.5L T2
any chance that i can get a circuit diagram that is all in one piece? im having a hard time following the current one.
Brian
Old 05-27-2008, 08:40 PM   #267
That's all I can do, since I did it with the different blocks I can't just get a full schematic.
Old 05-27-2008, 09:05 PM   #268
Engine: 2.5L T2
perfect. that should do it.
Brian
Old 06-01-2008, 07:04 AM   #269
PM sent.
Did not receive yet. Check email to confirm which address is sent because Latham address is former employer and no good for delivery.
turbo.shaft is offline
Old 06-01-2008, 05:47 PM   #270
My Ride: '88 Horizon R/T
Engine: 2.4L DOHC
Can this device take the turbo HEP signals as input, and output the 2.0 crank output? (ie, could I use this to convert my turbo HEP signals into the Neon crank signal so that I can run the damn MS off my distributor? hehe) Awesome little device.
UnaClocker is offline
