No pics yet, it hasn't stopped raining for the past two days and I only had the prototyped circuit up until tonight. The stock distributor is used, with the HEP only. Take the cap and rotor off, put some screws in to hold the HEP in place and that's it. The signal could be transfered to a cam, not a crank. Technically, you could make up your own sensor with hall/optical pickups on it as long as it would produce the same output as the stock HEP.
What your distributor would look like:
And finally, here it is:
http://moyerautomotive.com/Documents/DIS_Adaptor.zip
All the info should be there, README.txt should be the first thing you open.
And a description of wiring modifications required:
Remove stock coil, cap, plug wires, and rotor
Wire coil + wire to center pin of Neon coilpack and noise suppressor
Wire coil - wire to coil input on adapter
Wire outer two pins of Neon coilpack to adapter
Wire adapter - to a good engine or body ground
Wire adapter + to a switched ignition run/crank source (not to coil +)
Splice into tan wires on Gray and Black HEP connectors and connect to adapter
The noise suppressor I speak of is that little black thing that bolts to the back of the driver's side of the head on the 2.0/2.4's.
I am investigating the possibility of an adapter to run the stock electronics off the crank/cam sensors for you 2.4/SRT swap people.
If you have any questions feel free to PM me or post here.
