Old 09-20-2007, 01:45 PM   #1
SRT swap mounts?
My Ride: 91laser
Does anyone know if there are mounts for an srt-4 swap into a 1991 plymouth laser? I got crucified for posting this on the dsm forum but I think it can be done. All they had to say was "it's a waste, the srt-4 has less potential and is weaker," "They aren't as fast as the 4g63" blah blah blah. I'm sur fab will be needed, but was just wondering if someone had mounts already available to save me some time and work. I plan on this swap to show the dsm crowd that there is an alternative to the same old 4g63t swap. A buddy of mine has a 2000 neon with an srt-4 swap said he thought someone had done it before, but he couldn't find the info. Any help is greatly appreciated,
Thanks in advance,
A.J.
91laser is offline
Old 09-20-2007, 04:38 PM   #2
My Ride: '90 Voyager
Engine: 2.5 16V Twin Mitsus
I could have sworn that the SRT head flowed better than an older 2.0/2.4 head, and oh wait, aren't the dsm guys running a reversed old 2.0 head? And being as the SRT internals are much nicer than the 4g63 (just from looking inside the blown 4g63 I have), don't you think the 2.4 (look at that, its a bigger motor, too!) is a better choice? I'd also like to know how many of those dsm guys are making 300 horse and 330 ft-lbs of torque reliably just by swapping on a kit from the dealer.
Maybe it's just because I hate Mitsubishi's....
Sorry, I don't have mounting advice, but I'm pretty sure its been done before so someone should know something.
90TurboVan is offline
Old 09-20-2007, 06:15 PM   #3
My Ride: 91laser
Exactly my thoughts. I've had 4 of these cars all of which have either dropped a valve, or the trans. went, or both. So I think it's time for something new. Hopefully somone has some info.
91laser is offline
Old 09-20-2007, 10:44 PM   #4
My Ride: 91laser
Someone? Anyone? I'd hate to go in this blind but if thats what it takes to get the job done so be it! Maybe suggest some mounts I might be able to modify to fit?
91laser is offline
Old 09-21-2007, 03:24 PM   #5
My Ride: DOdge Shadow ES
Engine: 2.5l
Gonna go out on a limb here and say no. I have never seen any avaliable mounts other than the neon one. It sounds like you have a really unique swap planned which means not enough people have done it to make producing mounts worth while. Time to get creative and spark up the welder.
DJ
turboshad is offline
Old 09-21-2007, 06:55 PM   #6
My Ride: 85 glh
no there will be nothing easy. don't forget the 4g63 is 180* the srt motor, and the pickups are totally different.
t3rse is offline
Old 09-21-2007, 08:03 PM   #7
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (21)
don't the mistsus rotate counterclockwise?not that that matterstoo much, just thinking the tranny mount might be a big challlenge.
dyno sheet
I practice what I preach:
1992 GTC convertible 2.5/568 aluminum fw/Tu 6puck feramic/s60/3in Tu sv/+40S/ FWD CAL /FMIC/self ported head+1mm exh valves/self ported ex mani/stock 2piece w/stock tb/PSSSSTSSSS
crazymadbastard is offline
Old 09-21-2007, 08:31 PM   #8
My Ride: 87 GLHS
You will need to use a 420a head with the SRT4 block to make it work. The reason that the 420a is backwards flowing is because the firewall doesn't have an exhaust dunnel like the dodge cars do.
In order to make it fit it had to have the intake in the back like the 4g63 since there just isn't room for the exhaust/turbo in the back side of the engine bay.
Of course you also need to swap the rest of the driveline including the tranny aswell. I assume that the mounting points are the same between the 1G and 2G eclipse which means that the front and driver mounts shouldn't be bad if you use an eclipse/neon tranny.
-Rich
rfb6435 is offline
Old 09-21-2007, 10:55 PM   #9
Don't even try and use the mitsu electronics. I have no idea how you'd do gauges and stuff with srt underhood wiring, maybe swap interior harnesses too and use srt gauges?
Couldn't you beat the firewall back enough to fit the srt head/turbo in there? Don't know how serious you are, but I removed the heater box and moved part of my firewall back to fit my turbos in (minivan). I wouldn't want to run the exhaust underneath the 2.4, the mitsu 2.0 had more space under there.
Mounts shouldn't be too bad if you have some steel and a welder, I read lancer for some reason which is why I thought there might be some info out there.
Axels should be interesting.
Old 09-21-2007, 11:29 PM   #10
Originally Posted by t3rse
no there will be nothing easy. don't forget the 4g63 is mounted 180* the srt motor, and the pickups are totally different.
+1. It's not worth the hassle, the 4g63 can make just as much power anyway. With what you'll spend to swap in an SRT engine properly, you can have a killer 4g63 engine. And if you don't do it properly, you'll just end up w/ a large pile of scrap metal on wheels.
There's a reason they do that "same old swap"
Force Fed Mopar is offline
Old 09-27-2007, 11:34 AM   #11
My Ride: 91laser
what about swapping into a later model 2G talon??
91laser is offline
Old 09-27-2007, 04:11 PM   #12
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
same probs
speeduphoria is offline
Old 09-27-2007, 04:48 PM   #13
My Ride: 87 GLHS
The 2G swap might be easier if you use the 420a reverse flow head on an early 2.4 block (the SRT4 head has a few passages that don't line up).
That way atleast you would be guaranteed that the front and driver side engine mounts from a 2GNT 420a engine would work. I am not sure if the frame mounts are the same on a 1G as the 2G for the 420a since the 1G came with the 4g63 family of engines... DSM guys always swap in a 4g63/4g64 rather than the chryco engines so you probably won't find much info on doing this swap into a 1G.
The 2.4 will be a problem though since you would need a custom oil pan so that you can run the exhaust under it... Overall it is a mess and it is very unlikely that anyone will ever do it since the 4g63/4g64 are perfectly good engines and actually are higher reving due to their larger bores and shorter strokes compared to the SRT4 engine.
The SRT4 engine does have some advantages but they don't really justify the swap unless you are just doing it to see if you can.
-Rich
rfb6435 is offline
Old 09-27-2007, 07:31 PM   #14
My Ride: 91laser
Well thanks for all the info guys. I don't know what to do. I have a 1st gen neon r/t with a built n/a motor, but I want to sell it and find something to put the srt motor into. Decisions, decisions.
91laser is offline
Old 09-29-2007, 02:06 PM   #15
Mo' valves, mo' boost
jonnymopar's Avatar
My Ride: Daytona ES
Engine: 2.4L DOHC
Originally Posted by 91laser View Post
I want to...find something to put the srt motor into.
*hint*
Jon J.
1989 Daytona ES 2.4L - MPH (and, turns out, MPG too!!)
2003 Neon SXT - MPG... yeah just MPG
jonnymopar is offline
Buy PSP | Loans | Honda CBR600RR | Loans | Loans
Page generated in 0.47663 seconds with 13 queries
