Why aren't you using TD injectors? The stock 2.4 injectors will not flow enough fuel under boost.
Your real main seal leak.. It's probably the distributor adapter you made, the end of that cam needs to be well sealed or it'll just pour oil out the end.
There aren't any. Unless you use a 2.2 flywheel and transmission like I did. This is why using the hard mounted crank sensor on the 2.4 is nice. You know EXACTLY where it is, and you just change the timing in the computer.
i didnt mod the dist at all, put it all together, bolted it up, and she started (rotating the dist until we got close)
anyone know where the timing marks are on a 2.4.... if any
I thought you needed to mod it to work, the dizzy also sends the injector signals. I have some td +20 injectors if you are interested you can have em real cheap for this project, as long as I get to drive it.
It wouldn't need that. Every vane is the same, they all look the same so it doesn't matter. But you do have to install the plug wires in the reverse order.. It'll be rotating counter clockwise instead of clockwise.
I think his biggest problem is he has no way of calibrating the fuel flow. It's a non-adjustable FPR, and a computer that is expecting one injector of a certain size, but getting 4 that equal a completely different size instead.
the td pressure regulator runs at a higher pressure too than the 2.4, no?
by the way Ryan how are things going?
do you know of a good source for a 2.4 long block? It just has to be rebuildable
so I throw some srt rod and piston in it. Stoping by the dyno tomorrow to spectate?
