Old 11-18-2007, 08:52 AM   #1
dsm2.0 head dohc swap
My Ride: 1989 lebaron gtc
Engine: 2.2turbo t2 shelby
Okay I have a couple ?s
does the mistu 2.0 turn the same way as the chry 2.5 there on opp side of the car I would think they would have changed the direction in the tranny?
I would like to do a hybrid conversion but I'm not sure it will work its out of a 91 laser I don't care if the exaust is out the front or not I can make that work I just wanted to make sure what head I had and flow numbers that kind of stuff , I can't find that info here does anybody have a website I can resarch this kind of stuff
and how strong is the mistu 2.0 lower end if I decide to change my mind
any help would be greatly appr.
Hemi417 is offline
Old 11-18-2007, 08:03 PM   #2
Re: dsm2.0 head dohc swap
My Ride: 87 GLHS
It has to be the Chrysler head from the 2nd gen eclispe/talon or an avenger. It is just an inverted neon head. The 1st gen is a 4g63 head and is totally different.
-Rich
rfb6435 is offline
Old 11-18-2007, 08:53 PM   #3
My Ride: 87 Shelby Charger
Images: 8
This is a '95 Mitsu reversed pattern head, with the '95 cams. I doubt I'll ever use it, gonna stay 8 valves.
boost geek is offline
Old 11-20-2007, 03:19 PM   #4
my head has a different valve cover on it but I checked the way the engine turned and it turns the same way
I took the valve cover off and the bolt pattern for the head bolts is the same as the 2.5 I have if I were to set the head on my engine it puts the intake out the front like alout of the hybrids I have seen
were can I look up numbers to find out what I have because I dont know anything about the neons as far as gen go and I think this motor had been swapped before
Hemi417 is offline
Old 12-13-2007, 05:18 PM   #5
My Ride: 91 Daytona
Engine: 2.4
99.9% of engines turn the same way, except older marine engines
Rock Kustoms is offline
Old 12-14-2007, 12:15 PM   #6
Some Honda engines turn CCW as well as some diesels. I think you have a 4g63 engine, which will not work. If the valve cover doesn't look like the one above I don't think it's the right engine.
1985ShlbyChrger is offline
Hotel Las Vegas | Free Credit Report | Ringtones | Buscador libro | Loans
Page generated in 0.29334 seconds with 13 queries
