01-08-2008, 09:32 PM
Re: 2.5 l neon
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
normally people just swap a 2.4(use an older one if you want to use stock electronics) into the neon, then turbo it, and many use megasquirt to run it, 2.4 and 2.0 have the same bolt patterns for transmissions. look at some neon web sites for much more detailed info.
01-08-2008, 11:28 PM
Re: 2.5 l neon
My Ride: Neons + Caravan
Engine: 2.5T
The 2.4L swap is an easy one... and VERY cheap to build thanks to the SRT-4. Get a stratus engine, put in stock SRT internals (like $400 at MOST for everything you need for the bottom end rebuild, like pistons, rods, rings, bearings, etc, from the stealership even!) and a bit of re-wiring, a mount adapter, and your ready to get some pretty quick times.
01-11-2008, 02:34 PM
Re: 2.5 l neon
My Ride: OMNI, ShelDak, TSi
Engine: 2.2 'GLHS style' TII
I have seen a pro rallye neon with a 2.5 turbo
pretty sure trans bolt pattern is the same...
01-12-2008, 09:07 PM
Re: 2.5 l neon
My Ride: 91 Shadow turbo vert
how do u need to modify the passenger side mounts? I'm really intrested in this and what do u do for wiring? do u just use the neons wiring??? that'd be bad ass and i think we may have a nice amount of room more in the engine bay.
01-12-2008, 09:29 PM
Re: 2.5 l neon
damn thats sexy lol
01-12-2008, 09:30 PM
Re: 2.5 l neon
r u sure ur not gonna have an issue with overheating?? that's a huge fmic in front of ur radiator
01-12-2008, 09:50 PM
Re: 2.5 l neon
Engine: 2.5T
I think I have seen that car on the dot org before... VERY sexy build. If I remember right... that is a fire extinguisher for the intake manifold, right?!?
