01-22-2008, 01:38 PM
Re: why does a 2.5 hybrid pistons not hit the valves
My Ride: '90 Voyager
Engine: 2.5 16V Twin Mitsus
They only hit when the timing is really far off. If you don't break a belt or have it jump like 10 teeth, it'll be fine. Most engines are interference from factory, ours are kind of odd for four cylinders.
The only way I can think of to actually measure it is to get the 1+4 intake and exhaust valves all the way open, set the head on a flat surface, measure how far off the surface the valves hold it. Check how high your pistons are at TDC, distance above/below the deck. Measure your piston dish. Subtract the piston popup distance (positive for piston above deck, negative for below) from the piston dish depth. Add to that the thickness of your headgasket. If that value is greater/equal to the head measurement, you have an interference motor. I think some people were cutting valve reliefs into the pistons in order to make a 16 valve non-interference.
