03-26-2008, 03:05 PM
#16
Re: Maserati DOHC swap in 85 turbo Laser
My Ride: TIII R/T
Engine: 2.2L TURBO III
the axles are different than any other car made etc i was told. there are performance cals that Cindy and Rick D are selling for the Masi16V. I'll be sticking it in something, its got Rick D for aftermarket parts so if you really want to spend the cash, you can make a 600HP monster as Rick makes the parts to do it with.
03-26-2008, 06:02 PM
#17
My Ride: 87 GLHS
Engine: 2.2 16V Maserati
Yeah +1 to what Extreme said, axles will not interchange, they are a whole different size on the inners. If you wanted to you *could* use the whole transmission and axles in the Laser with custom mounts and adapting the shifter from the TC as well. The axle 'outers' have the same splines and the overall dimension from hub to hub is the same on a Laser or a TC Masi. Hope you never need another clutch though...
But then again, I'm just using my Masi's for what was it Orthodonti, oh yeah, 'Garage Decoration'
Alan
03-26-2008, 06:14 PM
#18
My Ride: TIII R/T
i love garage decorations that sound and goo faster than non decorations
04-05-2008, 01:33 AM
#20
First what are you WHP goals? 550 WHP? Thats litterally more than what is usable on a street car, great for a stripped down full race car. 300 WHP and the car will fly, much more than that on the street is a waste, you'll spin the tires more than move the car. A S50 T04E will spool super fast on the Masi and make a hair over 400 WHP. Then comes fitting the Holset, the things is huge, making a custom header? The Masi header is like a TBI and will put the Holset right there on the firewall. A Holset is in my garage waiting for my Rampage, but it won't be a street car. A giant turbo can make you much slower on the street. Find out what you want to use the car for and we can help with a turbo choice. Doing a cal custom for it will really be nice
Rob Walsh
84 DC Shelby Rampage
86 GLHS 76
87 GLHS 306
89 CSX 187
89 turbo mini
70 R/T SE Challenger
04-05-2008, 05:34 AM
#21
My Ride: TIII R/T
a holset wouldnt mount to a factory Masi header anyways, totally different flange. The IHI turbo is an efficient turbo capable of at least 17psi and it spoils very fast. its not really junk. if you want anything other than it you need a custom header
04-05-2008, 10:21 AM
#22
My Ride: 87 GLHS
What year is the donor TC? You may already have a common block  if it is a '90. There is even a small chance that if you have an 89 built after July 88 it's a common block as well. Is it really worth it to you to build a 'whole new motor' with custom pistons when you may just be able to throw a crank/rods at waht you have. You will need to bush the small end of TII rods to work with the stock Masi pistons but they are VERY stout right from the factory. IMO the .330 lift cams of the Masi's are more suited to high RPMS, building a 2.5 takes away that ability to spin the motor to where it gets happy. Sometime reinventing the wheel is the hard way...
Alan
04-05-2008, 10:41 PM
#24
My Ride: 85 GLHT, 87 ShelbyZ
The 16v masi uses it's own unique Forged crankshaft and rods.
04-05-2008, 10:42 PM
#25
My Ride: 87 GLHS
The 89 TC is the only FWD Mopar'ish car that could have come with any one of FOUR forged crankshafts.
Forged non common block
16V forged non common block
Forged common block
16V forged common block
But no, since we already know it is a DOHC car then it uses a specific crank/rods/pistons/bearing etc. So you can swap for a standard common block crank but the rods have a different sized piston pin (small end) so yes, you could use some TII rods and have them rebushed (pressed)
But like I said, you may be able to run what you have already, did youestablish if it truly spun a bearing and was it a main or a rod. Got pics yet?
The car is either an 89 or a 90, realistically speaking, there are no 91 DOHC TC's. THere is one and I've seen it but that was a VIP backdoor deal and dataplate calls it a 90 anyway.
Is the donor car gone??
Alan
04-06-2008, 07:03 AM
#27
My Ride: TIII R/T
have you checked for the pump block off plate to rule Common or non common block?
04-08-2008, 01:35 PM
#29
the engine is the easy part, need to buy a cal and wideband from him. The key to how the car runs. Jay is going to get some plenum matterial soon too  Got paid lol Did you want to copy his current build or the old one though? Jays little tube header is "one of a kind"
The paint doesn't matter that much in the TC stuff. Most of it is just finding ANY PARTS in the first place lol.
Rob Walsh
86 GLHS 76
87 GLHS 306
89 CSX 187
89 turbo mini
