04-08-2008, 05:45 PM
#31
Re: Maserati DOHC swap in 85 turbo Laser
he was running a stock 2 piece I believe, I don't think it was modded. My ported exhaust manifold and a stock head. That was the way it has been running. He hasn't run the tube header yet, which flows less volume than my ported manifolds lol. But it should run better anyway with it. The head is getting ported and slightly bigger valves put in. Jay and me are tag teaming an intake. I have done the porting and he has done the cutting. So we'll both have great plenum intakes. Jays car was the first known on the net to run a TBI cam, which he uses. His car was the second to use my PT lifter mod too. The new head gets the valve springs I use the sweet Comp Beehives. So the new engine will make a ton more power, but I don't think the mileage will go down unless he goes to a big cam. He should be able to hit 350 WHP with a S60 turbo and the TBI cam with the new engine easy and keep the mileage. My guess is he'll not like the S60 as I did with those mods, the S60 just spools way too fast and hurts traction. As of the last time it ran, Jay could reproduce the set up easy. As it was it was a full boost and shift at 3,000 RPM set up and still fast. I have bad luck with 2.5s, there all a turd
Rob Walsh
84 DC Shelby Rampage
86 GLHS 76
87 GLHS 306
89 CSX 187
89 turbo mini
70 R/T SE Challenger
