Old 05-13-2008, 09:07 AM   #16
Re: UP-date.... Motor is in!!!!
Originally Posted by turbomini View Post
would you be willing to sell those after you get your new ones? i dont want to spend no 269 on gear..
We'll see. I might just get a pair of used 8v ones and use the bushings again.
shelbyplaya is offline
Old 05-15-2008, 07:21 AM   #17
MEOW!
My Ride: lebaron
Engine: 2.2L TI(ish)
Images: 137
well if you deside to keep them would you be willing to get a pic of the bushings? i can make them if i know what they look like. but if you do get new ones keep me in mind for the bushings
turbomini is offline
Old 05-15-2008, 08:50 AM   #18
ok i will.
Old 05-17-2008, 12:47 AM   #19
MEOW!
My Ride: lebaron
Images: 137
ok thanks
and what intake you using?
Old 05-17-2008, 08:59 AM   #20
My Ride: Omni
Engine: 2.2 liter 16V hybrid
Hey good job, it remember me some souvenir! It's a lot of work to get a 16V conversion but the result is fantastic.
The Long runner caravan intake will give you more low end torque to spool the turbo but will kill top end..just FWI.
Are you using stock electronics?
ciao
guidsm is offline
Old 05-17-2008, 05:04 PM   #21
ciao
The motor is GOING to have ALOT of torque!!!! I'm going to be running stock electronics till i get the motor set up how i would like it. Then it's getting a megasqurit. After that, tuning
Old 05-17-2008, 05:12 PM   #22
My Ride: 88 reliant 91 tona
what kinda IC is that? i ahve the same one... haha i was thinking about running my pipes under tho instead of cutting holes
reliantwagon is offline
Old 05-17-2008, 05:32 PM   #23
It's an e-bay IC. So far it's worked real good.
I would worrie about damaging my IC pipes running them under the x-member.
I'd rather cut a cuple small holes then replace my charge pipes.
Old 05-17-2008, 05:53 PM   #24
My Ride: Omni
Go Ms !
I run mine Msn'spark ..i love it
guidsm is offline
Old 05-17-2008, 06:17 PM   #25
Go Ms !
I'm still trying to deside if i want to run it off the stock hull effect or go with EDIS.
Old 05-17-2008, 09:28 PM   #26
My Ride: Omni
only a 36-1 on your crank is what you need.. You put 2 vB921 driver in the MS and fire the Neon coil...
If you look on the sticky i have put base timing map and how to use stoc dodge sensor for IAT and coolant sensor
guidsm is offline
Old 05-25-2008, 10:58 AM   #27
Motor is running! the car moved under it's own power for the first time since september 15th yesterday! i just have to plum in the rad and do the down pipe.
Old 06-02-2008, 08:40 AM   #28
Well boys... The car has now become my DD. All i can really say is... WOW.
overall driveablity is so much better! i havent layed into it yet. saving that for after it's broken in and i get the bigger turbo and the IC plumed in as well.
Old 06-02-2008, 10:43 AM   #29
My Ride: '88 Shelby Z TII
Cool..
Reaper1 is offline
Old 06-07-2008, 12:15 AM   #30
I got the IC mounted and plumbed in tonight! One of my buddies came over and helped me out. I used ALOT less piping then I was planning. The IC is mounted a bit higher then i was hopping, I bolted it right to the top rad support. I guess I'll have to do some air ducting to it. I s still need to get a BOV welded onto the pipe.
I guess It's time to focus on the exhaust....
all we've desided is that my exhaust is gonna be an open dump.
I'll get pics of the IC install later.
Oh and I also got a Ford EDIS 4
Free Advertising | Mortgages |
