'87 Chrysler Town & Country SRT-4 - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Go Back   Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more! > Turbo specific > 16v Conversion
Old 06-15-2008, 09:43 PM   #1
My Ride: '90 Voyager
Engine: 2.5 16V Twin Mitsus
90TurboVan is keeping the peace
It all started back in November/December 2007. We found a '87 Woody wagon at an insurance auction that had been an engine fire. We'd already been buying wrecked SRT-4's for resale, and had a few parts cars around. You can guess where our minds went...
Specs:
'87 Chrysler T & C body, power everything with load leveling
'05 SRT-4 engine and transmission (20k miles)
'04 SRT-4 engine and under dash harness
'04 SRT-4 Stage 2 PCM with toys, cluster, SKIM, Keyless entry
SRT gas tank and emissions controls
Front and rear SRT discs
SRT ABS
Front SRT struts and knuckles
K-car 5 speed console and shifter
Modified power split bench seat
Working A/C
LeBaron 16" lace wheels to clear brakes
Giant intercooler off of a wrecked SRT
Quiet 3" exhaust that dumps under the car
I have 112 pics, here are the important ones.
Drivetrain, suspension donor...
The finished product
With Cruiser wheels, the LeBaron ones are more sleeperish even though these look better.
SRT wheels are entirely too big
Engine pictures:
Original 2.2 Turbo I
Its level
The motor we ended up using
Axles
Done underhood
Turbo clearance
SRT Trans mount bolted right to the k-car body mount. The space there is taken up on the other side of the motor.
Upper right mount. Had problems with a bolt in single shear snapping and went to this hybrid mount. No problems since.
SRT bottom torque bar. Mount fabbed onto the k-frame.
ECU sits right where it does on the SRT. A little close to the fan, but this shroud happened to be broken perfectly to accomadate it.
Suspension and Brakes:
ABS module and SRT booster
Rear brakes with SRT discs. SRT rear hubs were chopped, milled, and drilled to bolt onto the K-car axle. Simpler than it sounds. Wagon e-brake cables work with the SRT backplates/shoes after the hole is drilled out slightly.
Modded SRT on left, stock wagon on right.
Front SRT struts were slotted for camber adjustment, strut mounts on the k-car were redrilled and ground out for clearance. SRT knuckles were used.
Intercooler, radiator, A/C, piping:
SRT lines were used, they exited the block on the passanger side stock. Chopped off, holes welded shut, block drilled straight through. I lengthened the short tube and shortened the long one.
Edit: Of course I did the above, but I really shortened the small tube and lengthened the large one.
Intercooler, inlet and outlet were moved around and bracketry fabricated. Only front end pieces removed/modified are the front radiator support for clearance and an air dam type thing was removed. Fits perfectly behind the reinforcment.
Resevoir for the intercooler sprayers. Its a washer bottle from an early 90's Dakota (old body style) with a hole made in the bottom for the toys pump.
SRT Stainless fuel line, rebent for k-car duty
Exhaust, glasspack has since been replaced with a quieter muffler
SRT PS cooler
SRT PS pressure switch is mounted to the SRT rack. Rack is too different or I'd have used it, so I put the switch here.
SRT hydraulic clutch, the steel ends of the plastic SRT line were used with tube TIG'ed to the end. Brake hose was used for flexibility.
Emissions:
Gas tank, used to prevent a CE light and for most stock operation. Rear floor moved up by an inch, the seat bolts right on after the mounts were extended. Result is not noticable.
Vapor cannister was hidden back with the load leveling pump.
Purge solenoid
Gas fill was made with a k-car fill end and various SRT bends cut and welded on. The SRT tube was much smaller and had an external vapor line, so I figured it'd be best to use it. Plus it works with the hose at the tank.
Everything else:
Clutch pedal. SRT master cylinder is mounted to a 5 speed k-car pedal assembly with stops welded on and limit switches mounted. SRT brake switch is mounted in a modified bracket. The master cylinder interferes with the heater duct going to the left vent, but a tube can be rigged (duct tape) to make it work.
Shifter, SRT cables were used with the ends chopped off and k-car ends welded on so a k-car shifter could be used.
SRT battery tray flipped 180 degrees and bolted in the front. It sets on the trans mount and it solid. The mount also holds the SRT vacuum solenoids and mounts the tube for the air filter.
That's an interesting key ring...
Split bench seat with each side narrowed slightly. Works out well with the 5 speed console.
Three pedals and a bunch of gauges and switches. Looks like fun...
I have to make a shroud for the gauges and put an acrylic face plate on them.
Broke this piece while trying to fit the radio, waiting to find another wood grain one without a message center.
90TurboVan is offline
Reply With Quote Quick reply to this message Share on facebook
Old 06-15-2008, 09:50 PM   #2
Re: '87 Chrysler Town & Country SRT-4
My Ride: 86 daytona cs
Engine: 2.2 t1
Images: 3
thedon809 is keeping the peace
Amazing thats the ultimate sleeper.
thedon809 is offline
Old 06-15-2008, 10:18 PM   #3
Garrett Booster
My Ride: Dodge Daytona
Engine: Turbo 2.2
Bbneon95 is keeping the peace
That is seriously bad. Almost as bad as shaft. awesome.
Bbneon95 is offline
Old 06-15-2008, 11:48 PM   #4
Mr. Moderator
My Ride: 89 Shelby Daytona
Engine: 2.4l
Images: 2
turbokid is keeping the peace
I have gone to heaven! That is purely amazing work!
MORE MORE MORE!
Old 06-16-2008, 12:13 AM   #5
Phatfoto is keeping the peace
That is some VERY impressive work. Awesome fab and fit.
Phatfoto is offline
Old 06-16-2008, 04:34 AM   #6
My Ride: 85 GLHT
Feedback: (9)
roachjuice is keeping the peace
holy shit thats bad ass!!
roachjuice is offline
Old 06-16-2008, 06:42 AM   #7
djmoyer is keeping the peace
I think that's what the 80's Camaro thought when we pulled away from him like he was standing still
djmoyer is offline
Old 06-16-2008, 07:23 AM   #8
My Ride: '85 Dodge Daytona Z
Engine: 2.2L TI
Tbone is keeping the peace
You are insane....but I like it!
Tbone is offline
Old 06-16-2008, 09:26 AM   #9
turbo.shaft is traveling down a dark road
Remeber to ofer it for sale here first if you ever get bored. I have first dibs. What is the 1/4 mile times and how is it on gas?
turbo.shaft is offline
Old 06-16-2008, 09:51 AM   #10
RIP
lotsaboost is keeping the peace
That is a delightful wagon. LOL. I had to say that. I was listening to a radio program about guns and the host said "that is a delightful gun". So if it's a good enough description for a Smith & Wesson, it's good enough for your wagon. What awesome work!
Any chance of it being at SDAC-18?
Carlos
lotsaboost is offline
Old 06-16-2008, 10:03 AM   #11
My Ride: 91 Spirit R/T,
Engine: 2.2 TIII
Feedback: (6)
rx2mazda is keeping the peace
that's pimp
rx2mazda is offline
Old 06-16-2008, 10:43 AM   #12
Carlos
VERY slight possibility of being at SDAC-18. If somebody would get the cruise to work, it would help the possibility. Carlisle is a definite.
djmoyer is offline
Old 06-16-2008, 10:27 PM   #13
My Ride: CSX-T
Engine: 2.2 T1
Images: 1
ljbprrfmof is keeping the peace
I want second dibs when you get tired of it, and I'll pay a dollar more than the first dibs. LOL!
ljbprrfmof is offline
Old 06-16-2008, 11:16 PM   #14
Mr. Moderator
Engine: 2.4l
Images: 2
lol he shouldn't get tired of that car!! It's too wicked!!
Old 06-18-2008, 03:02 PM   #15
It's too much fun to get tired of :)
25 mpg on this last tank, and that isn't driving for economy. No 1/4 times yet, soon hopefully.
Gear in this thread - Powered by O'Reilly Auto Parts
First Name
Please enter your first name. Invalid names will result in account termination.
Location
Where you live
Insurance
Please select your insurance company (Optional)
Ride
What do you drive?
Human Verification
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
