Can I attach a srt4 head to a 1989 t2 common block?? - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Go Back   Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more! > Turbo specific > 16v Conversion
Old 01-24-2012, 10:17 PM   #1
My Ride: 578125@gmail.com
ArieZ is keeping the peace
Ok so I am currently building a turbo Omni and am well on my way building a t2 thanks to all the advice from people here.(best staff in the business) today my friend informed me he has a whole mess of SRT4 parts I can use to build another motor...Is there a way or is it better to use a SRT4 head on a 2.2turbo block?? Here is a list of what he has for me to use, any advice on what else I would need to make this work would be super appreciated. This would be going in a 1990 Omni...
SRT4 Parts list...
Downpipe, charge pipe(hot side), stage 2 waste gate, Mitsubishi T15 turbo, 20psi boost gauge, manual boost controller, stage 1 or stage 2 injectors, oil pressure gauge,air fuel gauge, Stage 2 SRT computer, intercooler.
ArieZ is offline
Old 01-24-2012, 10:20 PM   #2
Re: Can I attach a srt4 head to a 1989 t2 common block??
TD Hardcore User!
My Ride: 92 Laser Turbo AWD
Engine: 4G63T
KillerTSI is keeping the peace
Yes you can put a srt head on a common block but there are some things to be modified. Look in the Hybrid section.
KillerTSI is offline
Old 01-24-2012, 10:23 PM   #3
Ok thanks... A hybrid, huh lol good name for it
ArieZ is offline
Old 01-24-2012, 10:25 PM   #4
TD Extreme User!
Feedback: (47)
tryingbe is keeping the peace
How are you planning to pass smog?
tryingbe is online now
Old 01-24-2012, 10:29 PM   #5
Lake county has life time smog in Californniaa so as long as I keep it registered it won't be a issue
ArieZ is offline
Old 01-24-2012, 10:29 PM   #6
TD Hardcore User!
Engine: 4G63T
Moving thread to the 16V conversion section.
Old 01-24-2012, 10:32 PM   #7
TD Extreme User!
Feedback: (47)
Easier and cheaper to swap in the entire SRT-4 engine.
Old 01-24-2012, 10:32 PM   #8
Ok thanks, sorry about posting in the wrong spot.
ArieZ is offline
Old 01-24-2012, 10:34 PM   #9
TD Hardcore User!
Engine: 4G63T
It's all good.
Old 01-24-2012, 10:37 PM   #10
Cheaper for sure if I could do it myself...I don't have access to any machine shop equipment or welding equipment so the brackets/mounts would be a nightmare and I'd have to pay a garage waaay to much to fabricate anything. So I'm just gonna push as much as reliably possible out of a 2.2
ArieZ is offline
Old 01-24-2012, 11:18 PM   #11
Legendary Driver
GLHNSLHT2's Avatar
My Ride: 85 GLHT, 87 ShelbyZ,
GLHNSLHT2 has really helped outGLHNSLHT2 has really helped out
if you can't make mounts for a whole SRT4 engine then you can't do the necessary mods to run an SRT4 head on a 2.2/2.5 shortblock.
GLHNSLHT2 is offline
Old 01-24-2012, 11:28 PM   #12
Ok...i didn't even know I could run it until a few minutes ago.. I haven't read on the conversion process but I figured there would be a lot lesss welding an fabricating than an entire swap..I'll have to read up On it and maybe just do a full swap when I get the money to have someone weld/fab mounts
ArieZ is offline
Old 01-25-2012, 12:02 AM   #13
Bite My Shiny Metal Azz
92TurboTona's Avatar
My Ride: 92 Daytona
Engine: 2.5L T1
Feedback: (26)
92TurboTona is ready to make a name for oneself
well you have come to the right forum, there several people that can walk you through it
92TurboTona is offline
Old 01-25-2012, 12:28 AM   #14
Super Pope
The Pope's Avatar
Feedback: (10)
all but 1 bolt lines up between the 2.4 and 2.2 trans, they use the 2.2 flywheel and clutch. So 3 of the 4 mounts have holes placing them off the 2.2 trans. Then you use the Neon passenger side mount adapter for gen 1 neon and a poly passenger side mount. No fab unless you want to.
Hybrids have offset pulleys and custom cam pulleys. Then your blocking off passages in the block and head for oiling. Then making big oil return lines out side the engine and external feed oiling too. The hybrid is a PITA that came about years ago before the days of the 2.4 turbo (in the US). Once a couple people did the whole 2.4 swap the hybrid days were numbered. Doesn't mean it is a bad setup, they work great. But a lot harder.
Rob Walsh
84 DC Shelby Rampage
86 GLHS 76
89 CSX 187
05 PT GT
93 Cummins
The Pope is offline
Old 01-25-2012, 05:50 AM   #15
TD Extreme User!
Feedback: (47)
A properly running 20 psi TII setup will run 12's in a Omni with slicks with mostly stock TII parts.
How deep is your wallet and how fast do you want to go?
Tags
common block, head, motor, omni, srt4, t2, t3
