Old 02-15-2004, 10:15 PM   #1
How to make oil restrictor?
My Ride: 1990 Dodge Caravan
Engine: 2.5 T1 Intercooled
I know you need to run an oil restrictor for the oil feed to the head, but how do I do that? I plan to drill and tap another hole in the oil distribution block and route it to the side of the head but where do I put/make the restrictor?
Thanks!
Ryan Lada
zombezoo is offline
Old 02-15-2004, 10:33 PM   #2
My Ride: No slicks Omni
You could snag the one out of your block (not being used anymore). It is taperd and could be firmly inserted into feed line.
russ jerome is offline
Old 02-16-2004, 01:49 PM   #3
Hybrid Booster
I made mine from one of the original oil fittings that screw into the front of the block. Basically I just cut it shorter, plugged the original hole where oil flowed into it and re-drilled it to 9/64" . Then added the extra flare fitting for the oil supply to the turbo.
You can see where I put this fitting in my other post with the engine pictures.
KClarryb is offline
Old 02-16-2004, 01:52 PM   #4
Hybrid Booster
another angle
KClarryb is offline
Old 02-17-2004, 06:09 PM   #5
oil restrictor
You need a fitting in the head to run your oil line to, right? I threaded the INSIDE of the fitting, put in a plug, and drilled to the appropriate size. You could also weld it.
FFWD is offline
Loans | Web Advertising | Western Union Money Order | Bible shop | Power Tools
Page generated in 2.01902 seconds with 14 queries
