02-25-2004, 09:32 PM
Hybrid Booster
Originally posted by zombezoo
snip>>>
Also, in regards to plugging the old oil feed in the head, how did you go about this? As far as I can tell the oil is fed up around the corner bolt into a hole drilled through the side of the head. I assume that you can simply drill the outer hole out to allow access to the oil feed hidden in the head bolt hole, tap that and install an allen head plug, then either leave the old plug that you had to drill out open or re-tap it to a larger plug and plug it again? If this is in any way unclear let me know!
Thanks!
Ryan Lada [/b]
Ryan,
I started to do mine like you described, then after taking another look I decided to put a 1/8 allen head pipe plug in from the top under the end cam bearing cap. I know it's not necessary but it does remove the only place you have oil pressure acting against the head gasket. Here's a picture.
