Old 07-03-2004, 04:27 PM   #31
90_Shelby
Peak torque about 5200rpm, peak power on the last run when we split the block was 5500rpm. (Yes we split the block, cylinder bore #3 now has a nice 2.5" crack in it. The head gasket was fine.)
Old 07-03-2004, 05:30 PM   #32
My Ride: 1989 Shelby Daytona
Engine: 2.2l
Images: 6
What year block were you using?
Shmiggz is offline
Old 07-03-2004, 07:41 PM   #33
1989 2.5 common block out of a minivan. I was talking to some people who had sonic tested a bunch of blocks, and the 2.5's were the thinnest. The new block is going to be filled, so I don't think we will have this problem again. The new block is a 2.2 89 T2 common block.
Race weight will be around 2725-50 lbs
Leon
FFWD is offline
Old 07-08-2004, 03:34 PM   #34
NO Democracy!
Leon, any timeframe when your car will be hitting the rollers again? Kinda anxious to see some new #s.
DirectConnection is offline
Old 07-08-2004, 04:19 PM   #35
90_Shelby
Most likely we'll have it back on the dyno over the next week...... Leons been out of town for awhile, so the marvelle bros. team is down a man.
Old 07-08-2004, 05:31 PM   #36
My Ride: No slicks Omni
Keep and eye out for this common block for future builups:
http://hometown.aol.com/russjerome/images/mexb1.jpg
Goofy big "C" on front. It's been mentioned in past on FMML and from Mopar engineers I am guessing it is not folklore. Mexican cast blocks bare that mark and are said to be thicker and more consistant for core shift. Late production RT's and supposedly used up at end of production 2.5 TBI's.
russ jerome is offline
Old 07-08-2004, 05:32 PM   #37
And awesome job with previous block testing! You guys rock.
Old 07-10-2004, 12:07 PM   #38
90_Shelby
Thanks Russ. We're tossing around some long rod, or de-stroker ideas. We're going to put this current one together, get it to the track, run some times, and then re-think our game plan over the winter.
Old 07-10-2004, 03:25 PM   #39
Long rod stuff would be interesting. I have a running 2.5 Tall block here if you guy's get into it, knowing you would test it makes it free! The early tall blocks are just non-common stuff but block filled and properly built it may help you build that 1.80 stroker you want.
http://minimopar.knizefamily.net/per...rodengine.html
1.80 stroke and a 16v......we are moving out of the 70's and strait to cutting edge race motors now
Old 07-10-2004, 07:27 PM   #40
NO Democracy!
That's been my gameplan for the past year. Destroke a stock 2.2 forged crank to make 2.0 liters. Neon 16v head conversion should really make some crazy peak HP #s! Looks like someone will be beating me to the punch as I haven't even finished my 2.5 sohc project.
Old 07-10-2004, 09:32 PM   #41
how do you destroke without changing to a differnt crank? i thought to destroke you had to go with a crank with a smaller stroke? did i misunderstand what you wrote?
QKsilverF1 is offline
Old 07-10-2004, 10:35 PM   #42
90_Shelby
If we de-stroked it, yes we would need a different crank. What we would do, is get a 2.2 forged crank welded and offset ground. V8 guys have been doing it for years.
The decision was made today to go with a 2.2. As per Russ' suggestion, pick up a mexican common block and get custom rods and pistons (no I'm not posting lengths or specs). We can fit a ring pack closer to the top of the piston, and use pin buttons, cause the oil ring will be on the wrist pin, and get a very respectable, 1.74 ratio. The 2.5 is around 1.45. We may run into problems with belt length going with the tall block, so this was our other option. We could always go with a bigger bore to make up some of the lost 18 cubes.
Someone was running chev rods in a 2.2 T3, anyone remember who?
Old 07-11-2004, 10:43 AM   #43
NO Democracy!
That would be Matt Leischer I believe.
Haven't heard much from him in a year or so.
Old 07-11-2004, 03:48 PM   #44
Matt is alive and well in AZ working at Hughes Performance, was just up here recently. Those were Titanium rods, so light they would give a guy wood just to hold in hand. He is trying another option with those rods so hold off on quoting the exact specs till it is up and running/tested again.
Old 07-13-2004, 03:36 PM   #45
You might want to try the SRT head gasket rather then the standard 2.4 gasket,
it has a thicker O ring built into it. TO make it work with a older 2.4 head you need to block the front oil return hole in both the block and the head. It's
heald up to a ton of power with my combo.
IMO, 26 degrees even with C 16 is alot of timing. I'd pull at least 6 degrees and try
agein.
RacerStev is offline
Loans | Loan | Debt Help | Free Ringtones | Debt Management
1320drag - Drag Racing resource Nissan 240 Forum Audi Forum My Chemical Romance Forum BonneVille Forum Chevrole Forum Camaro Forum Car Audio Forum Car Video Forum Canadian Mutsang Forum Dodge Intrepid Forum Emma Watson Fan Site GM Forum Tuner news GT cars Honda Forum
