Old 06-26-2005, 09:02 PM   #1
Lobe separation
Millerman340's Avatar
My Ride: 91 spirit r/t
Engine: TIII
On the dohc cams, Can you change the lobe separation with the adjustable cam gears? Sorry I'm used to single cam setups. Dave.
Millerman340 is offline
Old 06-27-2005, 10:46 PM   #2
Engine: TIII
Sorry I found the info ,Lobe Center: This is also referred to as lobe separation angle. Lobe center is measured in degree comparisons between the intake lobes and the exhaust lobes from the center of the camshaft. Since most imports are DOHC this number can be tailored with the use of cam sprockets. DOHC engines have two centers because of the use of two cams. Since changing the degrees on the cams can widen or shorten the lobe separation angle this number is often ignored. On single-cam engines this number is fixed since the intake and exhaust lobes are on the same shaft
Prepaid Credit Cards | Record Internet Radio with Tags | Visa Credit Cards | Mortgage | Personal Finance
Page generated in 0.30402 seconds with 13 queries
