Old 10-12-2005, 09:27 PM   #1
turbo snowmobile "holset"???
My Ride: 92 Spirit R/T
Engine: T-lll
1/4: 13.100
i was watching a snowmobile video and it had a ski-doo 800 with a holset turbo from a cummins on it now how in the hell does that work lil big i would think. dosent give much info other than it is off of a cummins does anybody know where i could get more info on this
440dart is offline
Old 10-12-2005, 09:45 PM   #2
Hybrid Booster
My Ride: 89 voyager van
Engine: hybrid dohc 16v 2.5l
Not sure where to go for info,sorry,but turbo 2 stroke's would be interesting.I'm into 2 stroke street bikes,and have seen pictures of them turboed,but never read much on the set-up.I would like to learn more about it,especially how they keep crank seals from failing...Good luck on your search!
whywoody is offline
Old 10-12-2005, 09:55 PM   #3
Its off a 4 cylinder cummins,
RAPTOR is offline
Old 10-13-2005, 02:14 PM   #4
Yeah I had seen pictures of a build up of a Snowmobile think it had a Holset too. Maybe a HX30?
mfpmax is offline
Old 10-13-2005, 03:02 PM   #5
My Ride: Shelby Daytona
2 strokes have lots of exhaust flow. I would think the exhaust turbine would get real carboned up after a short while but its prob a drag sled right?
afsautoworx is offline
Old 10-13-2005, 11:32 PM   #6
Engine: T-lll
1/4: 13.100
no these guys are around my area these are mountian sleds if any of you guys are into snowmobileing you should check out thunderstruck 4 there are a couple turbo sleds that sound pretty cool and are pretty quick its a good movie
440dart is offline
Old 10-15-2005, 01:54 AM   #7
Engine: T-lll
1/4: 13.100
when i looked at the skidoo that had the turbo it looked like a rather large turbo like a 6cyl cummins
440dart is offline
Old 10-15-2005, 02:43 AM   #8
turbo sled
My Ride: 1991 Daytona Iroc HT
Engine: 2.5 intercooled
i saw a sled at my local track pull a low 9 sec 1/4 mile
nasty. guy could barely hold onto it when he punched it out
never saw under its cowl but i heard compressor whine.
ThreeTurbos is offline
Old 10-15-2005, 10:26 AM   #9
My Ride: 87 Z
Engine: 2.2 (+.040)
wonder how much boost it was running... the rotax motor uses a rotary valve instead of reed valves- thus carb tuning for it would be nearly impossible. I shouldn't say that... anything is possible but if you've ever seen what a rotary valve looks like or how it works... I'd figure it'd bind into the side of the case, with pressure against it... That's why Bombardier uses a 4 stroke for the new supercharged motors.
87shelbyt2 is offline
Old 10-15-2005, 03:55 PM   #10
turbocharging works just fine on all kinds of 2 stroke engines. just think of the rpms those things turn, and that they move twice as much air since they fire every engine rev. makes that 800 cc engine become alot larger if you do the math.
xrattiracer is offline
Old 10-15-2005, 07:56 PM   #11
+++ Im sure that snowmobile is spraying a lot of nitrous.
Old 10-15-2005, 09:22 PM   #12
My Ride: 87 Z
Engine: 2.2 (+.040)
Not saying it's not possible... I'd just like to see how it's done on a "SkiDoo" which uses the rotax engine. I have a "SeaDoo" XP with the 800cc Rotax, it turns 110hp stock. I'm fully aware of the potential. Just that 2stroke is very picky about the size and shape of the exhaust pipe, so throw an obstruction in there... and like I said, ya got this spinning disc that has a window cut it in to time fuel delivery... mounted right smack-dab against the case before the ports. I would think that any pressure against that disc would cause it to grind into the case. Heck the case has marks on it from the rotary valve rubbing on it anyways... this is just me reverse engineering the idea...
MPAA | Loans | Edinburgh Hotel | Silver Shop | Bankruptcy
Page generated in 0.40730 seconds with 13 queries
