10-28-2005, 01:01 AM
My Ride: 2004 SRT4
Engine: 2.4
The stock cast crank will handle 350hp no problem. The rods and pistons are crap on either the sohc or dohc. You can get more than 350hp out of one, but I'm trying to factor in it being able to go 100,000 miles at least. On the sohc, get a magnum head or swap to dohc. A full race ported sohc will flow better than a stock magnum or dohc, but port those and they will blow the sohc head away in terms of flow. You can boost a stock motor, just don't take it past 230hp at the crank or you'll start to run into some internal problems. 8psi max. I'd run 6 myself and tune on the safe side and save the motor.
