Old 11-02-2005, 03:47 PM   #1
3.0L Head Gaskets...
My Ride: 1991 Daytona Shelby
Engine: 2.5L
Is it really true that the DOHC Gaskets work on the SOHC? If so that is great news because 3SX makes the oversized piston gaskets for the DOHC car. I am going with the .125" oversized setup. This gives me 3.15L. Of course I am going to sonic test my block first for any issues with the casting.
Frank
Frank is offline
Old 11-02-2005, 04:14 PM   #2
My Ride: 1994 Dodge Shadow
Engine: 3.0 6G72
i have also heard this is true. i could feesably see this as the mitsu 3000gt VR-4 shortblock that i have looks just like a SOHC engine... excet for a few things like where the oil filter mounts.
...if i had my shadow's 3.0 apart i'd go test fit the head gasket on that block to see, but i don't. but from a glance they look the same.
dodgeshadowchik is offline
Old 11-02-2005, 05:44 PM   #3
Frank, I just went shopping.
Im going with Cometic headgasket. Its 95mm and its only 70 bucks a piece unlike the 130 a piece 3sx ones. Importperformance.com
Also flatlander sells them??
I was asking this question on the boards over on 3si.org.
I was actually shopping for 6g74 and 6g75 headgaskets. They are not quite as thick as the stock headgasket, but I called mitsu and they are only 53 bucks a pop from the dealer.
Im going .096 over because that matches up to the biggest total seal rings I could find around that size.
Ondonti is online now
Old 11-03-2005, 10:38 AM   #4
Engine: 2.5L
Thanks all for the information. I may go with the 0.096" over pistons because Total Seal is good. This will be good because I need the oversized gasket for this setup like you. Left you all feedback. Thanks!
Frank
Frank is offline
Old 11-03-2005, 10:54 AM   #5
Ed over at total seal has been very good to me.
Ive got a quote # for my specific rings your could ask him about.
Looks like I am going Cometic .054 thick. I told Venolia last night that would be my gasket thickness when they called me confirming some information.
Im a bit scared of trying the 6g74-6g75 gaskets, and the cometics are not much more expensive then the big bore mitsu stockers.
Old 11-03-2005, 10:54 AM   #6
I think final bore is 3.683. Ive got the # at home.
Old 11-13-2005, 11:19 PM   #7
My Ride: 90 Lebaron GTC
Engine: 2.5 TII
Have any of you bothered to try contacting ROL? They make very good headgaskets that are very well spoke of by anyone I spoke with running them on turbo Fords.
crazyace is offline
Debt Consolidation | Jewelry Store | Mortgage Calculator | Song Lyrics | Debt Consolidation
Page generated in 0.44458 seconds with 13 queries
