Old 11-11-2005, 12:41 PM   #1
92 Stealth RT Turbo
Bob
My Ride: 06 Charger,99 Dakota
Engine: 5.7L,5.2L
What spark plug should I use ? Parts catalog shows NGK PFR-6-11J or Nippondenso PK20PR-11. I have not tore into it yet. The front bank will be easy but the rear bank is going to take some work. This car has been setting for several years. Is there anything I should look for problem wise? The car is not running real good at the moment. My neighbor just bought the car for his son and I am trying to help them out. I have no experience with these cars and am in the the dark on alot of it. Thanks.
Bob is offline
Old 11-11-2005, 01:02 PM   #2
Blue Iroc R/T's Avatar
My Ride: 93 Daytona Iroc R/T
Engine: 2.2l TIII
My son has a 92 Stealth R/T TT. I'll have to check with him on recommended Spark Plugs. http://www.pbase.com/rmscott/chads_stealth
As far as things to check;
If you have no record of the timing belt ever being changed and the car has over 80k on it, get it changed ASAP. Then while you are there, change the water pump. That engine is a Zero clearance engine. Which means; if you brake a timing belt, you WILL bend valves. Changing the belt is a PITA. That is the good part of it. IF you have a dealer do it, go to a Mitsu Dealer instead of a Dodge Dealer (very few Dodge Tech's know anything about this engine). A Dealer will charge approx. $1,500 to do a Timing Belt and Water Pump. Also when you change the belt it is advisable to also change the belt tensioner.
Check out www.3si.0rg forum for a lot of info on the Stealth TT/3000GT
Hope this helps.
Ralph
Blue Iroc R/T is offline
Old 11-11-2005, 01:12 PM   #3
Bob
Engine: 5.7L,5.2L
Thanks for the info. I will let them know about the timing belt. I will let a Mitsu dealer do that. I work at a Dodge dealer and none of the techs here have done one or want to do one. I am not sure if I want to even do the spark plugs on it!
Bob is offline
Old 11-11-2005, 01:15 PM   #4
Bob
Engine: 5.7L,5.2L
I will also check out the sites you have mentioned. Thanks again.
Bob is offline
Old 11-11-2005, 02:27 PM   #5
My Ride: 88 sundance
It may be easier to put the car on a lift and try to put in plugs from underneath also
jdawg is offline
Old 11-11-2005, 03:16 PM   #6
Bob
Engine: 5.7L,5.2L
Intake plenum needs to come off on this car.
Bob is offline
Old 11-11-2005, 10:09 PM   #7
Engine: 2.2l TIII
^ Absolutely.
Another site to check out that has a lot of performance parts for the Stealth TT is: http://www.3sxperformance.com/
Here is a write up on the Spark Plugs;
http://www.3sxperformance.com/ignition.asp
The Best: Denso Iridium Set of 6 IK24 Spark Plugs is $89.95
Ralph
Old 11-12-2005, 04:01 PM   #8
My Ride: 1986 Shelby Charger
Engine: 2.2 SOHC
The upper plenum can be unbolted and lifted away with nearly every vacuum connection and electrical connection left intact. Just lift it out of the way and change the plugs.
The service is the 60K and 120K service of the Tbelt, tensioner and water pump. Remove the IC pipes along the driver side of the engine bay and the driver front wheel. The plastic flashing from inside the wheel well needs to be pulled away. From there on out it's not hard. I did it putzing along in a couple of hours. Stealth 316 is a greta site that has a step-by-step guide for the 60/120 service and will save you 1500. The parts to do it I believe are 450-500.
Aaron Miller
GLHandGTS is offline
Secured Loans | New York Hotel | Credit Counseling | McDonalds | Virtual Private Server
Page generated in 0.42685 seconds with 13 queries
