Old 03-27-2006, 05:29 PM   #1
Max boost on stock 4G63
My Ride: 1999 Integra GSR
Engine: 1.8 DOHC VTEC
I told my friend he could use my MBC until I get back into the boost of things, how much boost will the stock fuel system on a Eclipse take?
89CSX#179 is offline
Old 03-27-2006, 07:48 PM   #2
My Ride: 86 daytona turbo z
Engine: 2.2 t1
it can handle around 16 psi. It all depends on when you get fuel cutout. be careful and dont push it too hard!!!! Try to rewire the stock fuel pump to get more fuel. easy mod/free mod will help also. Dsmtuners.com/dsmstyle.com/dsmtalk.com all help out with that
GOOD LUCK!
skippyman87 is offline
Old 03-27-2006, 08:07 PM   #3
My Ride: omni
Engine: megasquirted 2.2
i was running 17 psi on a forced performance ported big t28, 3 inch full exhaust, with only a rewired fuel pump for a fuel mod and i would rarely hit fuel cut on a cold night.. but on a 2g at least, the stock stuff is ok for quite a while. just keep an eye on your plugs if you change something
saw wave analog is offline
Old 03-27-2006, 11:03 PM   #4
Well I put my MBC on my friend's GS-T and its set at 13psi, we got cut out about three times. The first time it popped off, but we put a fastener on it and it stayed, after that it cut-out one more time and then it stopped. We only did pulls in 2nd gear cuz we were in the center of town but I told him to do it in all gears but also to take it easy for awhile. Its a 91 GS-T, it says TD05H on the compressor housing, are these the stock turbos(14b is what i understand but maybe its the same thing). And in the the TD05H the same thing as on the SRT-4?
Old 03-27-2006, 11:39 PM   #5
My Ride: '04 SRT-4
1/4: 12.920
If you're asking if it's the same as the SRT-4 turbo, then no. The SRT-4 uses a Mitsubishi TD04LR-16GK-6cm2. It's essentially a small 16g compressor mated to a small TD04 exhaust side (that's integrated into the exhaust manifold).
Eric
blackbird is offline
Old 03-27-2006, 11:59 PM   #6
O, thx for the info
Old 03-29-2006, 07:25 PM   #7
Well now its cutting out again every time, which is weird its only set to 14psi max. It must be his car, its a 91 with like 158xxx miles on it all stock. Prolly not a good idea in the first place.
Old 03-29-2006, 08:29 PM   #8
Hey 89csx, are you going to Renegade this weekend. They're opening the track for test-n-tune. Just wondering cuz my bro is gonna run his eclipse but I'm not sure if I'm going to take my 'tona. I don't want to be the only TD not running.
Wormser is offline
Old 03-29-2006, 10:04 PM   #9
Wow another yak-towner, I prolly cant this weekend Im working. Dustin will most likely be there, Ill try to go I doubt Ill run tho.
Old 03-30-2006, 12:19 AM   #10
Actual;ly from Sunnyside, but I figure people would know Yakima better than my little shit-town.
Wormser is offline
Old 03-30-2006, 01:05 AM   #11
Theres nothing wrong with Sunnyside
Old 03-30-2006, 01:24 AM   #12
My Ride: omni
if the 1g is an auto they have smaller injectors, different cams, and a 13g turbo.. i think the 13g is a td04 though..
ive been out of dsms for a while.. but you will max out the stock fuel system on a 1g auto a lot sooner than you would on a manual car
Old 03-30-2006, 01:30 AM   #13
Its a manual, and it says TD05H on the compressor, Ive looked several time because I've seen that somewhere else before, I know I have.
Old 03-30-2006, 01:37 AM   #14
eh, it was homemadeturbo.com, thats where I saw it, but yea its the stock turbo. Smokes a little, i told him to rebuild it. My other friend's 98 GSX smokes way more, but he has axle problems and cant race cuz his car starts wobbling very badly at above 50mph(axle problem is what he was told, Im not 100% sure)
Old 03-30-2006, 10:15 AM   #15
Im gonna be out, but I blew the csx up... bad. So no racing for me. Im trying to talk my buddy that has that black 89 t2 to go. He should.. my drag radials are just sitting being neglegted! Along with my slicks... but no one is using them untill I do! lol
TurboShadowES is offline
Debt Consolidation | Loans | Personal Loans | Skateboarding | Optical Illusions
Page generated in 0.69883 seconds with 13 queries
