Old 04-05-2006, 11:51 AM   #1
89 shelby 2.2 t2 help
my shelby has low boost around 5 then you hear a sound like air flutter cant seem to find a leak
hogtownhustler is offline
Old 04-08-2006, 02:39 PM   #2
anyone no this????????????
Old 04-08-2006, 02:53 PM   #3
Engine: 2.5 turbo
Do you have BOV on the car?
slasky is offline
Old 04-09-2006, 04:41 PM   #4
might wanna post this is the HELP section..probally get more responses!
89ShelbyGuy is offline
Old 04-23-2006, 04:23 PM   #5
My Ride: 1990 Acclaim, 1970GS
Engine: 2.5L, Buick 455
The air flutter sounds like compressor surge to me. If you have a BOV it might not be working at lower boost applications. I know I had one that would work fine after 5 PSI but under 5 PSI I would get compressor surge like crazy.
Erik
TIIAcclaim is offline
Old 04-23-2006, 06:59 PM   #6
leak found
leak found but dont no what i need to fix it.......it seems to be coming from where the swingvalve bolts to the turbo looks to b a gasket there but im being told there is not so im kinda lost at the moment
Old 04-24-2006, 01:16 AM   #7
My Ride: 86 Lazer-89T2 power
Engine: 89 2.5 T2 built
I,ve read that axle grease will seal the turbo flange to ex. mani. , you might try it on your swingvalve. No gasket is used on swingvalves.
ButchSuppe is offline
Old 04-24-2006, 11:25 AM   #8
well if there is no gasket how can i fix the leak??? and y is it leakin if there is no gasket to go there..............do i just need to buy a new one maybe mine is warped???????i dont know as im new to the turbo's
Old 04-24-2006, 05:43 PM   #9
Here is the gasket for the T3 o2/downpipe (bottom of page)
http://www.roadraceengineering.com/f...andgaskets.htm
you can get gaskets. Look for one on a DSM site for a T3/T4 swap. They all use gaskets.
They have an turbo inlet exhaust gasket for $8
85woodywagon is offline
Old 04-24-2006, 06:00 PM   #10
Thumbs up
well after more reserch into the problem i found the cat was stopped up and the air had to go somewhere so i took it off and replaced with a pipe fer now and it runs like a top..........thanks fer all inputs
Mortgage Calculator | Creative Electronics | Free Advertising | Car Insurance | Loans
Page generated in 0.44255 seconds with 13 queries
