06-06-2006, 09:50 PM
#21
you cant use a remote mount without an oil pump.
Thats why I want you to mount it in the engine bay. You need gravity to drain the turbo.
Just take the exhaust from the passenger side underneath (avoiding the oil pan so the pipe isnt so low that it hits stuff when you go over bumps. bring it up on the drive side. Do the same with the driver side exhaust, Join the exhaust paths, then put the turbo on wherever you have room to also fit a downpipe in. I still havent seen any decent pictures.
I just looked at some of those pictures you put up and it looks like you might have more 'safe' room on the passenger side. as long as you can fit a downpipe then you should be fine.
If you have ever seen what v6 headers look like on a transverse fwd car, you can do the exact same thing, except since your moter is longitudinal, your exhaust will all come together on one side of the engine bay where you put your turbo. Put the turbup up high where the big empty space is in front of the passenger strut housing. You dont even need actual v6 headers, just route both exhausts to one side of the motor.
Its really simple as that for the manifolding. I dont know what you manifolds actually look like or how they connect though.
