07-17-2006, 10:28 AM
#16
My Ride: '69 chevy, '03 WRX
Engine: 358 600hp, 2.0 turbo
Not a huge fan of VW, but I will say that I think their best car of all time is the beetle RSi. It is sick. There is a local guy who has one, it sounds nasty!! It has the VR6 turbo, Porsche calipers, etc..etc. I do like the N/A vr6 sound.
07-17-2006, 03:38 PM
#17
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
I don't think that car had turbo, but it did have the 3.2L 24v VR6. Looks similar to the Golf R32 package.
Was there ever a production turbo VR6? What about the 2.7L bi-turbo Audi S4 engine, was that VR6?
07-17-2006, 06:38 PM
#18
Nah, I am 99.9% sure that the Beetle RSi has the vr6 turbo. It is awd too. I have seen one. I saw it the first time in GT4 (for playstation), and didn't think it was real, but then I saw one at a local VW dealer and got a closer look. Its a sick car!!! I think you have to order it, and have it sent here to the US. They retail, I believe, for $70,000, but don't quote me.
07-18-2006, 12:00 PM
#21
My Ride: 91 Spirit R/T
Engine: TIII
Both the VR6 and 16V engines can be made to perform very well with forced induction. I've got 2 VW friends that are playing around with FI on thier rides. One is a MKII Jetta with a VR6 swap in it. Right now he's running a Vortech SC, non-intercooled and 12 psi-ramps gradually to 18 @8krpm. That car is a fricken blast! All that's done there to lower compression is a headgasket shim. I beleive he's sitting around 9.5:1 compression.
The other is running an older GTI with a 16V turbo setup. It's just about finished. Just waiting on the header to be welded up. It ran good and hard last year with megasquirt, 11:1 compression and a 75 shot of nitrous. Now it's 8.5:1, ported head and intake, T3/T4 57 trim. it should really fly in a couple weeks.
07-19-2006, 11:34 AM
#22
Originally Posted by 89acclaim
Guess I was wrong. sorry bout that. I guess the RSi I saw had an aftermarket/homeade turbo setup.
07-19-2006, 08:03 PM
#23
It happens to all of us, don't worry.
A Vr6 swap into a scirocco could be fun. http://www.jwelty.com/jwelty3/carysciroccovr6.html
Though I would like black and not as low.
Though if you are looking for something different instead of a TD how about a 2.3 turbo ford car?
Daniel Merrill
07-26-2006, 06:29 PM
#27
Engine: TIII
Originally Posted by TurboShadowES
I hate VW's. they are a royal pain to work on. Take everything you know about how normal cars are put together, and make it backwards and you have a VW.
stay far, far away...
Naw, they are actually prety simple once you understand how they work. Before I understood it I would cringe when asked to work on them. The later fuel injected cars are very easy but the older Bosch system is a bit confusing at first.
06-05-2007, 01:00 AM
#28
My Ride: 1986 laser xt t-tops
Engine: turbo 153
i have worked on a couple vr6's and yes you could i also worked on a couple audis with turbo-charged 5 cylinders and that could be a good potential but pricey you know how much those krauts want for parts? thats why i stick with dodge they made it easy and cheap for us to get lots of power with big wallets lacking big money!!!
06-14-2007, 03:17 PM
#29
My Ride: 89+90 Daytona Shelby
Engine: 2.2 TII, 2.5 TI
Older VWs aren't any more complicated than our TDs when you get down to it. The mechnical injection system is a blessing and a curse. It's a pain to fix, but it is very versatile. The ability to swap parts from any like-engine on those cars is nice too. I kept trying to convince my friend to do a turbo 16V swap on the Scirocco. I even offered to give him a spare Mitsu turbo and a manifold to cut the flange off. But he decided to go with a 2.0 16v N/A build-up instead. In a little car like a Scirocco (1700 lbs), it will fly. I wouldn't want a VR6 in one because it's heavy and throws the weight off a LOT, but the VR6 and the 16v 4-cyl. can put down some serious power. I'm not sure about the VR6, but the 16v engines ARE interference, so make sure your timing chain is good!
