Old 09-12-2007, 10:50 PM   #16
My Ride: Looking
Thats too cool
Any updates?
What did he use for front suspension?
TurboNoob is offline
Old 09-13-2007, 05:24 PM   #17
My Ride: 05 SRT-4 ACR
Engine: 2.4 DOHC
Originally Posted by 440trk
Hopefully, he's gonna pull that 8 3/4 outta there, and put a Dana in. That rear *while plenty strong for most applications* is going to have a short life if that setup makes the kinda power it should. I know a few folks who grenaded their 8 3/4 with stout 440/auto combos and big sticky tires (much smaller than the steamrollers on the back of that Daytona). The 'tona being fairly light, will help...but that rears gonna be the first thing to give up the ghost.
I really like that project though! I'll be curious how he likes that fuel injection setup too....
Mike (440trk)
8 3/4 are a very stong rearend, a dana is nice but chrysler did put the 8 3/4 behind any hemi automatic. I dont think he will have a problem with it.
89daytonashelby is offline
Old 09-14-2007, 05:38 PM   #18
how many hours so far into fabbing all this up? that looks SICK
shlbyZ is offline
Old 09-19-2007, 08:27 PM   #19
My Ride: 86 Shelby Charger
Engine: 2.2L Turbo 1
that will be so friggin amazing...
turbo-charger88 is offline
Old 09-22-2007, 07:56 AM   #20
My Ride: 1989 Daytona Shelby
Thank god it is not a t-top car or it would twist in two!
ShelbyMopar89 is offline
Old 09-24-2007, 09:54 PM   #21
Wow, I am totally speechless! I just saw this and called several friends to check it out! Simply amazing!!! Those look like Holset HX35s... pull the dang silencer ring out of them already!
MerkXRTurbo is offline
Old 09-27-2007, 11:56 PM   #22
My Ride: 87 Daytona Shelby Z
can somebody say, sleeper? what do you think it will put to the flywheel? im guessing around 650, maybe more
docta J is offline
Old 09-28-2007, 01:49 AM   #23
My Ride: Dodge Neon SRT-4
Engine: 2.4L 16v
With a 440ci engine and two pretty large turbos, I would venture to say that 650 is way underestimated unless he's running some very low boost.
On proper boost, that thing should have no problem putting over 1000 hp to the tires if the motor can hold somewhere around 30 psi.
Annihilator is offline
Old 09-28-2007, 10:01 AM   #24
Nice!!! Looks like an intercooler plumbing nightmare though. Your dad better get a hood with a full length, 12" buldge on it.
Looks like a fun project!!!!
John O
Crete, Ne.
PUNKslip is offline
Old 09-28-2007, 12:08 PM   #25
man 1000whp!!! thats insane!!! i wanst thinking too much, it was late. i know that the lingenfelter z06 has the LS7 (427ci) with a twin turbo setup and it makes like 725 to the flywheel. your right though, bigger engine and most likely bigger turbos for you. i feel like an idiot now
docta J is offline
Old 09-28-2007, 01:14 PM   #26
Engine: 2.4L 16v
No worries man, your number might be closer depending on what they decide to do with the setup, but it doesn't appear that we'll ever hear an update on this thing.
I posted that number because I have a friend with a 355 cubic inch chevy motor with two ebay turbo's and off brand wastegates that puts down about 850 hp at the wheels, and he has no intercooler or methanol injection, just race gas, 12:1 compression, and 12 psi. It runs the equivalent of a ~9.0-9.2 @ ~155 mph quarter mile (we only have a 1000' track, longer than 1/8th mile, but not a full quarter).
Old 10-03-2007, 06:48 PM   #27
Re: 1989 Daytona Twin turbo 440 big block
My Ride: 2003 Dodge 2500
Engine: 5.9L cummins diesel
I agree that the 8 3/4 is an extremely tough rear axle, and if braced in the right manner by someone who knows how to weld without getting it to hot and tweaking it (It happens quite often believe it or not) it would handle that combo. That being said personally i would run the dana just for extra insurance. The reason i say that the 8.75 will hold up is because there is a good friend of my dad's who has a 71 challenger that has made a best pass of 7.91 at 180.89 mph with an 8.75 in it. Its powered by a 500 cube all aluminum hemi (older KB block with Indy heads) I have seen the time slip. Since then the only thing that has been changed is he went from 2 1150 cfm dominators to 2 950 demons to make it more liveable on the street. Thats right, its steet driven. It spends more time on the street then it does on the track. Oh yeah, and its a 4 speed (the definition of bad ass). If you go to the Mopar Nats you have probably seen it. Its tubbed and purple, cant miss it.
HolsetShelby is offline
Old 11-14-2007, 10:53 PM   #28
My Ride: LHS, SD MXZX 800
Engine: 2-stroke 808cc
That is gonna be wild. He does need to rid of the 8 3/4. its a good rear end but not strong enough. A moderately built 440 makes 400hp then add a twin-turbo setup on it say he has it on E85 (112 octane) he can run probabally up to 15lbs of boost with a 8:1 compression setup. my estimate 1300hp at the rear wheels. in a striped and caged daytona that weighs about 2900lbs thats 1hp:2.23lbs for power to weight. that is gonna be F@*%ing nuts
MXZX is offline
Old 11-24-2007, 06:40 PM   #29
My Ride: Turbo Hilux
I hope they do some more work on that arse end before they go throwing big hp through it....the top shock mounts look a bit anorexic and they should tie the two 4 link hoops together to prevent flex for a start..
It is looking good though, has a lot of potential.
I wonder if anyone can tell me what brand of efi that is on top of the 440?
Cheers
VT-44 is offline
Old 03-04-2008, 12:04 AM   #30
I've worn lots of shoes
itsbudda's Avatar
My Ride: 1987 Lebaron
Images: 30
any news on it?
BUUUUH! DANG IT BOBBY! - Hank Hill
Jason Betsch._________________________
1987 Chrysler LeBaron Coupe- Needs work. :)
1993 Ford Ranger-shot ball joints, sensor problems, Just your typical ford :)
ShelByQue FTW!!!
MEOW!!!!
I'm looking for an overhead console for a J/G body with a blue interior, and a working compass. if anyone knows of one, please pm
itsbudda is offline
Sprint Ringtones |
